Statistics- Find Critical Value(s); Bell-Shaped Curve
  • Thread starter Thread starter oddjobmj
    Curve Statistics
The discussion focuses on finding critical values for various alpha levels in statistical tests using the Bell-Shaped Curve. Specifically, it addresses three scenarios: α = 0.05 for a two-tailed test, α = 0.01 for a left-tailed test, and α = 0.005 for a right-tailed test. The user, Odd, seeks clarification on the correct interpretation of alpha, which is defined as the "alpha-level" or "probability of error level," not standard deviation. The conversation emphasizes the importance of understanding the context of alpha in hypothesis testing.
  • Understanding of statistical hypothesis testing
  • Familiarity with the Bell-Shaped Curve
  • Knowledge of alpha levels in statistics
  • Basic concepts of one-tailed and two-tailed tests
  • Research how to calculate critical values for different alpha levels
  • Learn about the implications of one-tailed vs. two-tailed tests
  • Study the concept of p-values in hypothesis testing
  • Explore graphical representations of the Bell-Shaped Curve in statistics
Students studying statistics, educators teaching statistical concepts, and anyone involved in hypothesis testing and data analysis.
oddjobmj
Find the critical value (or values) for the following and illustrate each using the Bell-Shaped Curve:
Numerous example such as-
1) [tex]\alpha[/tex] = 0.05, two-tailed test
2) [tex]\alpha[/tex] = 0.01, left-tailed test
3) [tex]\alpha[/tex] = 0.005, right-tailed test
This is what I'm looking for. I believe the solution will be rather simple once I have some context but I was absent and am not sure where to look for how to solve these questions. Unfortunately my book doesn't have a glossary and I've re-read the chapters we were supposed to be going through to no avail. Google is yielding many results but none of which are using a variable [tex]\alpha[/tex] and because there are many different types of tests I can't figure out which one I'm supposed to use.
Thank you for your time,
Odd
EDIT:
I believe, in this case, a (alpha) stands for standard deviation. However, I'm still not sure what the standard setup of this problem would be since I'm -only- given a. Nothing more.
α (alpha) is not the standard deviation. It is the "alpha-level", or "probability of error level", or "p-value". Does this help?
12K
