Centripital acceleration problem
  • Thread starter Thread starter benji
    Acceleration
The discussion revolves around a problem involving centripetal acceleration related to a kitchen gadget that spins lettuce to remove water. The problem specifies the radius of the container and the rotation rate in revolutions per second, prompting participants to explore the calculation of centripetal force at the outer wall.
  • Participants discuss the need to determine the centripetal acceleration and the relevant formulas. There are attempts to clarify the relationship between revolutions per second and tangential speed, as well as the importance of correctly identifying the radius.
The discussion is active, with participants sharing their equations and calculations. Some guidance has been offered regarding the conversion of revolutions to tangential speed, and there is an ongoing exploration of the correct radius value. Multiple interpretations of the problem are being examined.
There is a noted discrepancy in the radius measurement, with participants clarifying that 12 cm equals 0.12 m rather than 0.012 m. The problem does not provide a mass, which affects the calculation of centripetal force.
benji
This is talking about one of those kitchen gadgets where you put the lettuce in the container and spin it so all of the water gets spun off.
The radius of the container is 12cm (0.012m). When the culinder is rotating at 2.0 revolutions per second, what is the magnitude of the centripetal force at the outer wall?
What have you done so far?
I assume they want the magnitude of the centripetal acceleration. So, what's the formula for centripetal acceleration? (Check the book!)
All I've done so far is looked at equations and wrote down what I know:
Equations:
Fc=m(Ac)
Ac=(v^2)/r
What I know:
r=0.012m
rps=2.0
Fc=?
Well you have rev/sec. How much distance will an object go in one rev? When you figure that out, you can find the "tangential" speed in m/s, and then your formula might make more sense.
hey, 12cm is 0.12m.
acc= (v*v0) / r
cirumfrance = pi * 2 * 0.12 = 0.24pi
so v = (0.24pi * 2)/1 = 0.48pi
acc = 0.48pi / 0.12 = 4pi m/s*s
i think!
Equations:
Fc=m(Ac)
Ac=(v^2)/r
That's the equation you want. To use it you have to figure out the speed.
What I know:
r=0.012m
Careful. 12 cm = 0.12 m, not 0.012 m.
rps=2.0
Fc=?
Now figure out the speed using v = distance/time. It goes 2 revolutions per second. Each revolution is the circumference of a circle: [itex]c = 2 \pi r[/itex]. Figure out the speed in m/s.
Forget the centripetal force (since you are not given a mass); you want to find the centripetal acceleration.
Thanks guys, this helped a lot.
  • · Replies 20 ·
