What does a three-dimensional matrix look like?
  • Thread starter Hypatio
  • Tags
    Matrix
In summary: Delta tIn summary, the matrix is a two-dimensional matrix that is used to solve a system of linear equations. This matrix is used to keep track of the solution at different points in time.
Hypatio
151
I am trying to figure out how to construct a matrix for solving systems of linear equations with two dimensions of space and a dimension of time, but I do not know how to do this or begin visualizing such a matrix. The solution depends on all the data at all times less than the solved time so I can't cheat by simply updating a 2D matrix.
For instance, it is very clear that a 2D matrix will look like this:
http://www.eecs.berkeley.edu/~demmel/cs267/lecture17/DiscretePoisson.gif
Do I add the third dimension directly below this, or to the right? or to the bottom right? I would assume to the bottom right since a system of equations which can be reduced to tridiagonal matrix will also be true for a 3D matrix. On the other hand, I do not how it would be possible to create a tridiagonal matrix with a 3D problem because you will refer to prior time levels when solving new time levels.
define what you mean by dimension
I'm not sure I can do that correctly without simply looking up the mathematical definition. The solution to my model has two dimensions of space, consisting of regularly spaced points. The dimension of time is also discretized so that I find the solution at desired times. The dependence on the time in the solution is due to a convolution integral so it is not a simple forward model where I can just update a 2D mesh, values for all times need to be retained since they depend on values at all previous times from the convolution.
I just want to know what the matrix is supposed to look like so that I can prepare the matrix gaussian elimination.
oh, so dimension is the number of arguments the solution depends on. If the equation is linear and contains a convolution in time, then performing a Fourier transform (with respect to time) will make the covolution a simplle multiplication of the Fourier componets. Then, it is a matter of finding the inverse Fourier transform, but there are methods for numerically doing that (FFT).
That sounds promising, but does matter if all the unit response functions are dependent on the time? My problem would be easily solved if the relaxation modulus was not time and space dependent. It is a linear viscoelastic problem where viscosity varies with time as well as space.
In any case, I still don't understand how a 3+dimensional problem can be numerically solved since I do not know how the matrix is constructed.
ok, i would suggest you start by showing us what the meaning of the matrix you linked in the op is and how you obtain it for the Poisson equation.
The equation solved is:
[tex]\nabla^4\phi\left (1+\lambda\frac{1-v}{E} \right )+\sum_{t_0}^t\int_{t_i}^t\left [k\frac{1-v}{E}\nabla^4\dot{\phi}-\left ( \frac{\partial^4}{\partial x^4}+\frac{\partial^4}{\partial y^4} \right )\dot{\phi} \right ]\exp \left [ -(t-t_i)\frac{\mu}{\eta} \right ]dt=\sum_{t_0}^t\int_{t_i}^t\dot{\epsilon_T}\exp \left [ -(t-t_i)\frac{\mu}{\eta} \right ]dt -\nabla^2 k\alpha_VT[/tex]
where:
nabla^4 is the biharmonic operator
lambda, v, E, k, aV, and mu are constant coefficients.
t is time (t_0 is start time and ti is a time between t_0 and t)
T is a variable (temperature)
phi is the scalar potential function which is what the solution finds.
the dot indicates derivative in respects to time
eta is the viscosity which varies in space and time
and
[tex]\epsilon_T=\frac{\partial^2}{\partial y^2}k\alpha_V T[/tex]
Finding the right side of the equation is quite trivial since epsilon is known, but since the convolution on the LHS involves the unknown stress function phi it will require more work in the dimension of time.
What does:
[tex]
\sum_{t_{0}}^{t}
[/tex]
stand for?
Dickfore said:
What does:
[tex]
\sum_{t_{0}}^{t}
[/tex]
stand for?
I see the notation is unclear. The amount of sum's depends on the time discretization. So you sum from time t_0 to t, t/Dt many times where Dt is the time interval.Maybe it is better written
[tex]\sum_{t=0}^{t/\Delta t}\int_{t_i}^tf(t)dt[/tex]
Ok, so is:
[tex]
\int_{t_{i}}^{t}{f(t') \, dt'}
[/tex]
a function of the upper bound [itex]t[/itex] (I used a different symbol for the dummy variable [itex]t'[/itex]) and then you take the sum of the values of this function for a discrete set of the upper bound [itex]t[/itex]?
EDIT:
Also, what is [itex]t_{i}[/itex]?
Dickfore said:
Ok, so is:
[tex]
[/tex]
I think that is right. So:
[tex]\sum_{t=0}^{t/\Delta t}\int_{t_i}^tf(t)dt=\int_{t_0}^tf(t)dt+\int_{\Delta t}^tf(t)dt+\int_{2\Delta t}^tf(t)dt...[/tex]
what you wrote is not what I said.
I'm sorry, I guess I didn't understand what you were asking. Is your question about the operation indicated by the summation and integration, or the term inside the integral or something else?
It's about the summation. What variable are you summing with respect to?
Oh I see. The value of t_i changes (increasing by Delta t) for each sum. So it is the lower bound that varies over summation. Meanwhile, the upper bound only changes when you are solving for a different time level.
So, does this summation because of some approximation of an integral or is it something fundamental from the theory?
The summation arises because of the dependence of the viscosity (eta in the equation) on time, and it is an approximation of an integral. If viscosity were constant, the variables epsilon_T and the partial differential terms for phi could be inserted into their respective integrals.
I'm actually wondering if there is a way to mostly reduce the summation such that I can use only some accumulated result from a previous timestep to evaluate the new timestep instead of performing the summation for all times for each timestep. I am reading a paper that says this is possible, but I am afraid that the time dependence will prevent this.
Actually, I was thinking you can switch the order of integration in the double integrals and perform one of the integrals exactly.
I don't see how this can be done?
Well, as far as I can see, you have a double integral of the form:
[tex]
\int_{t_{0}}^{t}{dt_{i} \, \int_{t_{i}}^{t}{f(t') \, \exp{\left[-(t' - t_{i}) \frac{\mu}{\eta(t')} \right]} \, dt'}}
[/tex]
If you change the order of integration, then you have to be careful about the limits of the integrals. The result is:
[tex]
\begin{align*}
\int_{t_{0}}^{t}{dt' \, \int_{t_{0}}^{t'}{f(t') \, \exp{\left[-(t' - t_{i}) \frac{\mu}{\eta(t')} \right]} \, dt_{i}}} \\
\int_{t_{0}}^{t}{dt' \, f(t') \, \exp{\left[-\frac{\mu \, t'}{\eta(t')}\right]} \, \int_{t_{0}}^{t'}{\exp{\left[\frac{\mu \, t_{i}}{\eta(t')} \right]} \, dt_{i}}} \\
\end{align*}
[/tex]
Now, the integral over [itex]t_{i}[/itex] is trivial (although [itex]\eta(t')[/itex] is a function of time, it is treated as a constant here).
I've gone through this again and I am confused about whether or not I am writing this out correctly.
The following should be correct for the term under question:
[tex]\sum_{t_0}^{t/\Delta t}\left ( \epsilon (t)^n-\epsilon(t)^{n-1} \right ) \left ( 1-\int_{t_i}^t\frac{\mu}{\eta}dt \right )[/tex]
where superscripts indicate time levels and
[tex]\epsilon(t)=\frac{\partial^2 T}{\partial z^2}[/tex]
I would think you could describe this as the integral
[tex]\int_{t_0}^{t}\frac{d \epsilon}{dt} \left ( 1-\int_{t_i}^t\frac{\mu}{\eta}dt \right )dt[/tex]
and that this could be simplified to
[tex]\epsilon(t) \int_{t_0}^{t}\left ( 1-\int_{t_i}^t\frac{\mu}{\eta}dt \right )dt[/tex]
but this does not give the correct answer. In any case, looking at the numerics it appears that it should be impossible to take [tex]\epsilon(t)[/tex] out of the integral without doing something fancy.
By the way, thank you very much for thinking about this with me.
1. What is a three-dimensional matrix?
A three-dimensional matrix is a data structure that stores information in three dimensions, similar to a cube. It consists of rows, columns, and layers, allowing for more complex and detailed data representation compared to a two-dimensional matrix.
2. How is a three-dimensional matrix represented?
A three-dimensional matrix can be represented in a variety of ways, such as a table with three axes (x, y, z), a stacked set of two-dimensional matrices, or a nested array. The specific representation used will depend on the programming language and the purpose of the matrix.
3. What are the benefits of using a three-dimensional matrix?
A three-dimensional matrix allows for more complex data organization and representation, making it useful for tasks such as data analysis, image processing, and scientific simulations. It also allows for more efficient storage and retrieval of data compared to other data structures.
4. How do you access data in a three-dimensional matrix?
To access data in a three-dimensional matrix, you need to specify the coordinates of the desired element using the three axes (x, y, z). For example, to access the element at row 2, column 3, and layer 4, you would use matrix[2][3][4].
5. Can a three-dimensional matrix have different data types?
Yes, a three-dimensional matrix can have different data types, depending on the programming language. For example, in Java, a three-dimensional array can have elements of different data types, while in MATLAB, a three-dimensional matrix can only have elements of the same data type.
  • Linear and Abstract Algebra
  • Differential Equations
