Come up with a sine equation for the following word problem.
  • Thread starter Thread starter supernova1203
    Sine Word problem
The discussion revolves around formulating a sine equation for a ferris wheel problem involving the Niagara Falls SkyWheel. The problem specifies the diameter, rotation time, and the height of the lowest point from the ground, prompting participants to derive an appropriate mathematical model.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the sine function format for the equation, discussing parameters such as amplitude, vertical shift, and period. Questions arise regarding the inclusion of time as a variable and the need for clarity on what the variables represent. Some participants suggest that the original poster clarify the problem statement and the specific equation sought.
The discussion is ongoing, with several participants providing insights and raising questions about the formulation of the equation. There is a focus on ensuring that the variables are well-defined and that the approach aligns with the motion of the ferris wheel. Some guidance has been offered regarding the relationship between height and time.
Participants note the importance of specifying the exact problem statement and the definitions of variables involved. There is an acknowledgment that the circular nature of the ferris wheel may require different mathematical considerations beyond a simple sine equation.
supernova1203
niagra falls skywheel, a ferris wheel has a diameter of 50.5 m and rotates 1 revolution in 2 minutes. the lowest point on the wheel is 2.5 m from the ground.
This is the equation i have come up with, please tell me if this is right or not, and if it is not please come up with your own equation and show me how you did it.
the base equation is y=aSin(k(x-d))+c
max height = 50.5m
min height = 2.5m
period = 2 mins or 120 seconds
vertical shift = max height + min height/2
=50.5+2.5/2
=53/2
= 26.5 m
vertical stretch = maxpoint -midpoint
or amplitude
=50.5-26.5
=24m
since there is no horizontal shift
y=asin(k(x-d))+c
y=24sin(2x)+26.5
or y=24sin(120x)+26.5 depending on how you look at the period in seconds or minutes.
You never stated what equation you are trying to find. Since this is a rotating wheel, wouldn't the variable t = time be involved? And if you are trying to keep track of a moving point on the wheel, wouldn't you need both x and y coordinates in terms of time? And wouldn't you normally use radian measure?
What is the exact statement of your problem?
um.. sine equation..sine function
y=asin(k(x-d))+c
that kind of equation
your supposed to find the vertical stretch = a
k=period/horizontal stretch/compression
d=horizontal shift
c=vertical shift
y=asin(k(x-d))+c
d=horizontal shift
c=vertical shift
Look, a ferris wheel is circular. I could just give you the equation of its circle which would have the form x2+(y-a)2 = r2. That would be the equation of the ferris wheel if you put in the correct numbers for a and r.
I assume that isn't the equation you want. But you haven't told us what equation you want. It apparently involves motion but you haven't addressed any of the questions in my last post. It might help if you would give exactly, word for word, the statement of the problem.
As LCKurtz has said, no equation makes sense until you say exactly what your variables represent. I think you want to say something like "y is the height above the ground of a specific point on the ferris wheel and x is the time in seconds." Further you need to specify which specific point, and it looks like you are taking y to be the height of one of the two points on the wheel that is at the same height as the center of the ferris wheel when t= 0.
hm... ok ill show you exactly what the question says in the attachment
heres the entire question :) hope it helps
max height = 50.5m.
Even taking everything everyone else has said, are you sure about this?
OK, at least now we know what the question was. I will get you started with a picture:
I have drawn it assuming the riders start at the bottom and the wheel has just begun turning. You have figures for r and d which, by the way, you should check. So express y in terms of r, d, and θ. Then you can express θ in terms of time t and you will have the height of the riders, y, in terms of t, which you can graph.
  • · Replies 25 ·
19K
