Solving Light Bulb Interference Issues
  • Context: High School
  • Thread starter Thread starter Drakkith
    Bulb Light Light bulb
The discussion revolves around issues related to flickering in newer energy-efficient light bulbs, particularly when used in a ceiling fan setup. Participants explore potential causes, including wiring issues, voltage sensitivity, and compatibility with specific fixtures.
  • One participant reports flickering when using two new light bulbs in a ceiling fan, while a combination of one new and one old incandescent bulb does not flicker.
  • Another participant suggests the possibility of a defective bulb and recommends testing with known good bulbs from other rooms.
  • A participant proposes that the wiring or setup of the ceiling fan may be reducing voltage to the bulbs, which could affect the performance of energy-efficient bulbs more than incandescent ones.
  • Concerns are raised about the suitability of CFLs in vibrating environments, such as ceiling fans, and a specific model is mentioned as being appropriate for such use.
  • Participants discuss methods for measuring voltage at the bulb socket, including the use of an outlet lamp socket and the potential safety risks involved.
  • One participant questions whether the fixture might be wired improperly, noting that CFLs may be sensitive to which connection is hot and which is neutral.
  • Another participant shares a similar experience with flickering bulbs in a dimmer circuit, suggesting that speed control circuits in fans could also be a factor.
Participants express various hypotheses regarding the flickering issue, with no consensus reached on the exact cause. Multiple competing views remain regarding the potential factors at play, including bulb defects, wiring issues, and compatibility with the fixture.
Participants mention limitations in safely measuring voltage and the potential for improper wiring affecting bulb performance. The discussion includes various assumptions about the setup and conditions under which the flickering occurs.
This discussion may be of interest to individuals experiencing similar flickering issues with energy-efficient light bulbs, as well as those looking to understand the compatibility of such bulbs with different fixtures and wiring setups.
Drakkith
Mentor
Hey all. I've got some of those newer light bulbs, the ones that are like 5-10 times more efficient than the normal ones and are usually built in a spiral shape on top of a piece which contains the electronics. Now, the issue I have is that I'm apparently getting interference or something in certain situations.
For example, when I put 2 of these bulbs in my ceiling fan in my living room, the bulbs flicker very badly. However, if I use 1 new bulb and 1 old incadescent bulb, I get no flicker at all. This doesn't make any sense to me because I've got multiple other new lights in pairs or 3's-4's in other rooms that have no trouble. I've tried turning off electronic devices in the room and even in my office, but it doesn't seem to help. Any ideas?
Science news on Phys.org
Perhaps you just have a defective bulb? Try a different pair of bulbs (I would take ones from the other rooms that we know are good) and see if you get the same result. Before one speculates about weird stuff happening, let's make sure it's a real phenomenon.
I've tried this. The same bulbs work fine in other rooms, and other bulbs have the same problem in my living room. It isn't too big a deal. I just use either 1 new light bulb or put an old type in there with it. Just kind of annoying. :wink:
I'm wondering if the wiring or setup with that ceiling fan is reducing the voltage going to the light bulbs, which wouln't have much effect on an incandescent bulb, but would affect the new energy style bulb. Most of those new bulbs are voltage sensitive, and there are warnings not to use them with dimmer switches or some automatic motion sensors which reduce the voltage going to the bulb. The electronics in these bulbs will overheat if there is insufficient voltage.
I'm not sure of a safe or easy way to measure the voltage, especially with the bulbs in operation. You'd have to tap into the wiring while everything was running.
Quite bizzare. I presume there are no dimmer switches or anything of that sort?
Results of some googling
Can I use a CFL in applications involving vibration such as a ceiling fan or garage door opener?
Generally it is not recommended to use CFLs in vibrating environments. Vibration can cause the electronics in the CFL to fail. There is one CFL bulb (FLE11) that is available for use in a ceiling fan. Check the package for this application.
http://www.gelighting.com/na/home_lighting/ask_us/faq_compact.htm#vibration
I presume that this occurs when you're not running the fan as well?
My biggest hunch would be that there's something special about the fan circuit itself. Please disassemble it and draw us a schematic.
:p
You could use an Outlet Lamp Socket
http://www.tools2parts.com/Leviton-L02-1403-W-p/1065-1255.htm
Disclaimer: Perfection is some idiot on the internet, perform at own risk.
Yes, an obvious way to tap into the circuit, one of that plugs into the lamp socket that has a plug as well as an lamp socket. I was a bit concerned about inserting wires or probes into the plug part of the outlet lamp socket.
Thanks for the responses. There is no dimmer switch and turning the fan on or off has no effect. I've got a multimeter at the house, could i use it to test the voltage coming out of the fan socket?
You probably could, and the results might be illustrative. It would be best to see it under load though (measuring the voltage across a flickering lamp).
I should also mention that it could be rather unsafe to do this with multimeter probes. You'd likely be in an ackward position trying to read the multimeter while keeping the probes on the contacts while they aren't touching you or each other without touching the contacts yourself. And if you're multimeter is older it might have exposed metal on the leads that you'll also have to avoid...
If I were to seriously investigate, I'd get the outlet lamp socket, harvest some plug from some junk lying around and connect the multimeter up to the exposed ends (carefully secured to avoid movement) using alligator clips. I would have the whole setup complete before turning on any power.
But again, I'm an idiot on the internet.
Awesome. I'll see what I can do. Thanks guys.
Is it possible that the fixture is wired improperly? The 2 connections on a light bulb are the center electrode and the threaded area. An incandescent bulb would not care which one was hot and which was neutral but a CFL might.
I've seen this effect too. In my case it was a 4-bulb light fixture with a dimmer circuit. They all flickered unless I put an incandescent in one position. Does your fan have a speed control circuit?
  • · Replies 24 ·
