Refractive index of materials at rf frequencies to make a smaller wire antenna
The discussion revolves around the refractive index of materials at RF frequencies and its implications for designing smaller wire antennas, particularly for TV reception. Participants explore the feasibility of using different media to enhance antenna performance and address issues related to reflection and absorption losses.
  • One participant inquires about the existence of a table of refractive indices for materials at RF frequencies and questions whether these indices are generally higher and if they correlate with low absorption losses.
  • Another participant expresses uncertainty about whether increasing the refractive index of an antenna's surroundings allows for tuning into a frequency band with a smaller antenna, emphasizing the importance of wavelength over frequency.
  • A participant notes that if the medium is not filled between the antenna and the receiver, significant reflection may occur at the interface with air, potentially leading to poor coupling.
  • There is a suggestion that the antenna could be designed with more elements if it is smaller, and concerns are raised about noise issues from RF waves escaping the medium.
  • One participant proposes using a spherical medium with a high critical angle at RF frequencies to minimize interference with the antenna, while also questioning how to address dispersion practically.
  • The concept of Snell's window is introduced, with a participant pondering its relevance to the shape of the medium's boundary and the antenna design.
Participants express various viewpoints and uncertainties regarding the relationship between refractive index, antenna size, and performance. There is no consensus on the effectiveness of using different media or the implications of reflection and dispersion.
Limitations include the lack of specific data on refractive indices at RF frequencies and the potential complexities introduced by dispersion and boundary effects.
material
I would like to ask a few questions. Does a table of refractive indices of materials at rf frequencies (say for TV) exists? Is there a way for me to estimate it for some materials? Are the refractive indices of these materials higher? Will those materials have low absorption losses at these frequencies? Would it be practical and sensible to make a TV antenna of smaller dimensions, and immerse this antenna in the medium? Could this idea work?
Science news on Phys.org
I'm sorry for doing this but I would really like somebody to give an answer to this question. I'm not sure if increasing the refractive index of an antenna's surroundings permits me to tune into a frequency band with an antenna that has smaller dimensions. My thinking is that wavelength is what's important in tuning an antenna and not frequency. Please help.
Unless you fill the space between the antenna and the receiver with the medium, the waves will have to exit the medium and enter the air. If the speed of the waves in the medium is significantly different than the speed in air you'll have strong reflection at the interface and the coupling with air will be poor.
This is one problem I may think about.
I don't know where you can find data regarding speed of RF waves in media.
Maybe try a search on Google Scholar.
Thank you for your reply. I missed that point about reflection at the boundary between the media.
Do you mean the space between the transmitting and receiving antenna or the space between the receiving antenna and the RF receiver? I'm assuming you mean the space between the antennas. I'm more concerned with reception than transmission. Reflection of RF waves at the boundary are a problem. If the antenna is smaller, then I could make a better antenna with more elements because the dime. As for total internal reflection, the reflection due to a traveling wave exceeding the critical angle only occurs from a medium of high refractive index to low refractive index. Some noise issues will occur from RF waves trying to escape the medium.
I'm suggesting this as a possible solution. The antenna should be small enough in size. The medium it is immersed in is larger and is shaped as a sphere. I am imagining that the reflections will occur close to the boundary of the sphere and will avoid interfering with the antenna. The medium selected has a high critical angle at RF frequencies if possible.
As for dispersion, I'm not sure how to deal with this in a simple, practical way. Calibrate the antenna to suit the medium? Add some electronic hardware that corrects for the aberration?
After seeing an article on Wikipedia on Snell's window, in which "Snell's window is a phenomenon by which an underwater viewer sees everything above the surface through a cone of light of width of about 96 degrees," maybe the shape of the medium's boundary and the antenna used is important somehow.
31K
