| New Reply |
Electron Fraction Calculation based on Density, Avagadro's #, Electrostatic Constant |
Share Thread | Thread Tools |
| Apr10-11, 08:02 PM | #1 |
A 2.0 mm diameter iron ball is charged to +48 nC. What fraction of its electrons have been removed? The density of iron is 7,870 kg/m3. 2. Relevant equations Q = Ne; N = number of atoms in 1 mole, e is atomic charge, Q = point charge N = Avagadro's Constant = 6.02E23 Proton Charge = 1.6e-19 C Electron Charge = -1.6e-19 C K = (9e9 Nm^2)/(C^2) vector<E> = (K|q|)/(r^2) A=4(pi)r^2 D=2r 55.845 is the atomic mass of Iron 3. The attempt at a solution I know that either the surface area of a sphere, or the Area of the spherical metallic ball comes into play but i do not know which one? i know that electrons will go to the surface of the ball or protons will go to the surface of a ball, and that the conductor internally has an electric field of 0 N/C. I also know that the density of the iron ball comes into play but have failed at connecting density with charge or even if there is a connection. I know that it will be a fraction of two things over one another since it is asking for a comparison. I know that 48nC is 3E11 electrons. i attempted to solve for E as a vector but got an answer that is way off by more than double. Q = Ne (6.02E23)(55.845)(1.6E-19) = 5.38E6 I then treated the ball and some other point source as a capacitor using the area of the surface of the sphere, plugging and chugging from this point on but got an incorrect number. i dont know how to start or tackle this problem :( |
| Apr10-11, 08:39 PM | #2 |
Recognitions:
You just need to find out how many electrons there are in total. So how heavy is a 2.0 mm iron ball? How many atoms does it contain? How many electrons are there per atom?
| Apr10-11, 09:12 PM | #3 |
V = (4/3)(pi)((0.001m)^3) = 4.19E-9 (7870kg/m^3)(4.19E-9m^3), meters cancel and 3.2976E-5kg = mass how many atoms does it contain? (3.2976E-5 kg)/(0.055845 kg/mol) = 1.84E-6 mol (1.84E-6 mol)(6.022E23 atoms/mol) = 1.11E18 atoms |
| Apr10-11, 09:31 PM | #4 |
Recognitions:
It would be, except you divided 3.2976E-5 kg by 55.845, which is in g/mol.
| Apr10-11, 09:39 PM | #5 |
| Apr10-11, 09:56 PM | #6 |
Iron has:
29 electrons 29 protons 30 neutrons the iron ball was charged to +48E-9 C (+48E-9)/(-1.6E-19) = -3E11 Number of Electrons from the Electrical Charge To account for the Electrons in an atom of iron; (1.11E18 atoms)(29 Electrons per atom) = 3.219E19 Electrons total present it as a fraction= (-3E11)/(3.219E19) = -9.32E-9; no units. (web assign claims the correct answer for Iron is 3.24E-11 with no units. Web Assign changes the metals and the Densities each time a new browser is opened and it is now getting late - i will have to do this over with another example) i still need help in solving this please. i do not know where i am messing up. i am stuck :( |
| New Reply |
| Thread Tools | |
Similar Threads for: Electron Fraction Calculation based on Density, Avagadro's #, Electrostatic Constant
| Electrostatic charge vs. Electric current: Effect on electron density of states | Atomic, Solid State, Comp. Physics | 0 | ||
| Cantilever switch based on electrostatic force | Mechanical Engineering | 10 | ||
| "verify that the number of atoms..." Avagadro's constant | Biology, Chemistry & Other Homework | 3 | ||
| Electron Density vs Electron Density Difference | Atomic, Solid State, Comp. Physics | 4 | ||
| fraction in combination...please tell me the calculation | General Math | 2 | ||
