Droplet impact angles, errors in.
  • Context: Graduate
  • Thread starter Thread starter TeraExa
    Angles Errors Impact
The discussion focuses on the mathematical relationship between the width and length of a water droplet to determine the angle of impact on a surface. As the angle approaches 90 degrees, measuring width and length becomes increasingly challenging due to the sensitivity of the angle calculation to small errors. The user expresses a desire to explore confidence intervals for impact angles and seeks guidance on how to proceed with this investigation.
  • Understanding of basic trigonometry, specifically arcsin functions.
  • Familiarity with concepts of angle measurement and geometry.
  • Knowledge of statistical methods, particularly confidence intervals.
  • Basic principles of fluid dynamics related to droplet behavior.
  • Research the mathematical derivation of arcsin in relation to droplet dimensions.
  • Study confidence interval calculations for angular measurements.
  • Explore fluid dynamics principles affecting droplet impact angles.
  • Investigate measurement techniques to minimize error in angle calculations.
Mathematicians, physicists, engineers, and researchers interested in fluid dynamics and droplet behavior analysis.
TeraExa
Hi
Arcsin width/length of a water droplet on any surface will give you the angle between the droplet trajectory before falling (assume straight line rather than parabola) and the surface upon which it fell.
As this angle approaches 90degrees (water drop falling vertically on a horizontal surface) measuring these two variables [width, length] will be more difficult as even a small error will result in a large difference in the angle calculation.
I would like to investigate mathematically this relationship, such as working on confidence intervals for angles of impact as functions of angle of impact itself etc. but I would appreciate some guidance as to how to go about it.
Thank you
Alex
replies
why did nobody reply? do i need to supply more information?
thanks!
:confused: :confused:
