How can I design a lab to demonstrate F=ma using masses and pulleys?
  • Thread starter Thread starter sarahowen
    F=ma Pulleys
The discussion focuses on designing a laboratory experiment to demonstrate Newton's second law, F=ma, using masses and pulleys. A recommended setup involves connecting two hanging masses over a pulley, measuring the time it takes for the heavier mass to reach the ground. It is emphasized that varying the masses on both sides is crucial for accurate results. Utilizing gravity as a constant acceleration source is advised, and resources like Tipler's physics book are suggested for further exercises.
  • Understanding of Newton's second law (F=ma)
  • Basic knowledge of pulley systems
  • Familiarity with experimental design principles
  • Ability to measure time accurately using a stopwatch
  • Research the setup and calculations for Atwood's machine
  • Explore the effects of friction in pulley systems
  • Learn about measuring acceleration due to gravity in experiments
  • Investigate variations of mass and their impact on motion
Physics educators, students conducting experiments, and anyone interested in demonstrating fundamental physics concepts through hands-on activities.
sarahowen
I have to design a lab to support that F=ma. we are using masses and pulleys but I'm not sure how to set this experiment up. anyone got any ideas? :confused:
thanks in advance 4 any help u can give me
sarah
There arte many posibel experiments with masses and pullys. But a lot of thm are about the efects of friction. A very simpel ekperiment might be just conecting 2 hanging masses over a pully and masure how much time passes until the havyer on reaches the ground. This should ofcourse be tasted with many diffrent masses on both sides.
By the way wathever experimet you set up it's usualy a good idea to use gravity as a form of acceleration. It is constant and you can easily control its size with a slide (the lass friction the beather).
Just take a general physics book full of exercises like Tipler. The most simple is the known as Atwood's machine: a pully with two masses.
  • · Replies 30 ·
  • · Replies 22 ·
15K
  • · Replies 19 ·
  • · Replies 66 ·
