What is more damaging: average power or peak power of a pulsed laser?
The discussion revolves around the comparative damage potential of average power versus peak power in pulsed lasers, particularly in relation to optical components such as detectors, lenses, and filters. Participants explore the mechanisms of damage and the relevance of different power metrics in various contexts, including thermal and nonthermal effects.
  • Some participants suggest that both peak and average power should be considered, noting that a significant difference between the two could lead to damage during peak phases even if average power is low.
  • Others argue that peak power is often more damaging, especially in cases involving femtosecond lasers, which can vaporize materials despite delivering less than 1 mJ of energy.
  • It is noted that damage mechanisms vary, including thermal, photochemical, thermomechanical, and nonthermal effects, and that the relevant mechanism influences whether peak or average power is more critical.
  • Some participants express uncertainty about the specifications in data sheets regarding power thresholds, questioning whether average or peak power is typically the concern for optical components.
  • There is a discussion about the distinction between energy density and power density, with some participants explaining that energy density relates to the total energy delivered over time, while power density refers to the power per unit area.
  • One participant emphasizes that the damage potential depends on the material properties and the duration of exposure, indicating that high peak power can cause localized damage quickly, while high average power may not cause immediate harm if applied over a longer period.
Participants do not reach a consensus on whether average or peak power is more damaging, as multiple competing views remain regarding the conditions under which each type of power is more critical.
Participants highlight that the mechanisms of damage are complex and depend on various factors, including the material's ability to dissipate heat and the specific characteristics of the laser used. There is also mention of the lack of clarity in technical specifications regarding average versus peak power thresholds.
narra
When we are considering the how much optical power a component/pin detector can withstand, are we more concerned about keeping an eye on the peak power or can we ignore the peak power so long as the average power is below some threshold value?
Science news on Phys.org
I'd guess that you have to look at both. If the peak power is only slightly higher, you could probably ignore it depending on what its for, but if there is a large difference you could burn something out during the peak phase even though the average power is low.
Even though the OP is rather broad, I'd say I've seen more components destroyed by peak power. Femto second lasers that deliver less than 1 mJ can easily vaporize many materials.
There are different mechanisms for damage- thermal, phptchemical, thermomechanical, and nonthermal mechanisms from ultrashort pulses.
http://web.mac.com/mfeit/physics/Michael_D._Feit_files/papers/jap8599.pdf
So the answer depends on the relevant mechanism. Pulsed lasers can deposit a large amount of energy in a short time, and so damage thresholds for pulsed sources are generally lower than CW sources.
Yes true. If a high peak power is delivered over a short duration on a material that can fairly rapidly dissipate the heat generated then it may not be of much concern, compared to large average power. But speaking more specifically regarding photo-diodes, fibre optic connectors, thin-film filters, prisms, lenses, mirrors and such like. When ever I consult data sheets the power thresholds are sometimes mentioned but never do they specify average or peak power, therefore I wondered if it was generally expected that average or peak power was the concern.
Thanks for your responses.
narra
narra
Ok- I didn't realize you were specifically talking about optical components.
My understanding is that peak powers are of more concern, but again, it depends:
http://www.semrock.com/laser-damage-threshold.aspx
Note, 'fluence' is an *energy* density, while intensity is a *power* density.
Useful link. Thanks.
ps How, physically, do you differentiate an energy density versus a power density, just that the latter gives the energy density over time?
Excellent question- I'm not sure, unless you consider the rate at which the absorbed energy dissipates in the object. Honestly, if you spoke to someone at Semrock I'm sure they would be willing to help.
If you are working with a cw (continuous wave) laser, you have to consider power density. It's simply the beam power (in W) divided by the surface area on which it is incident. If this ratio is above a certain limit, you'll scrap the material.
If you are working with a pulsed laser, then you must watch for the energy density as well. If the pulse from your laser is 1J, than the surface area of the absorbing material must be, say 1cm square for it not to burn. This defines the energy density threshold.
In the pulsed case, it is assumed that the pulse rate is sufficiently low that the power density is not exceeded.
As for the original question, much depends on the material. A high peak-power pulse can do much damage in no time, but very locally. On the other hand, a high power beam may do no damage if it's on for only a few seconds, but completely melt or ignite the material if left for minutes.
www.gentec-eo.com
9K
