Basic analysis: Proof by induction on sets
The discussion focuses on proving by induction that the set [a_{n} | n_{0} ≤ n ≤ n_{1}] is bounded. The base case is established with a_{1} ≤ a_{1} + 1. The inductive hypothesis assumes that for a given n, there exists an M ∈ R such that a_{n} ≤ M for all a_{n}. The challenge arises in extending this proof to a_{n+1}, where the suggestion is to consider the set {a_n | n_0 ≤ n ≤ n_1 + 1} and establish its bound as max{a_{n+1}, M}. The discussion also highlights the importance of clarifying whether "bounded" refers to both upper and lower bounds.
  • Understanding of mathematical induction
  • Familiarity with set theory and notation
  • Knowledge of real numbers and their properties
  • Basic concepts of bounded sets in mathematics
  • Study the principles of mathematical induction in detail
  • Explore the definitions and properties of bounded sets
  • Learn how to apply induction to sequences and series
  • Investigate examples of proving bounds for sequences
Students in mathematics, particularly those studying real analysis or discrete mathematics, as well as educators looking for examples of induction proofs related to bounded sets.
K29
Prove by induction that the set [tex][a_{n} | n_{0}\leq n \leq n_{1}][/tex] is bounded.
[tex]a_{n}[/tex] are the elements of the sequence [tex](a_{n})[/tex]
[tex]n \in N[/tex]
Definition of set bounded above:
[tex]\forall x \in S, \exists M \in R[/tex] such that [tex]x \leq M[/tex]
Just proving its bounded above here...
Base step: [tex][a_{1}][/tex] The set has only 1 element and
[tex]a_{1} \leq a_{1} +1[/tex]
Now assume true for [tex]a_{n}[/tex]
[tex][a_{n}|n_{0}\leq n \leq n_{1}][/tex]
and [tex]\exists M \in R[/tex] such that [tex]a_{n} \leq M, <br /> forall a_{n}[/tex]
For [tex][a_{n+1}|n_{0} \leq n+1 \leq n_{1} ][/tex]
... well I'm not really sure what to do here. Normally you use the assumption to prove it true for n+1, but I'm not sure how to incorporate the assumption here.
Please help
and [tex]\exists M \in R[/tex] such that [tex]a_{n} \leq M[/tex],
for all [tex]a_{n}[/tex]
To do induction, you should consider the set [tex]\{ a_n | n_0 \leq n \leq n_1+1 }[/tex]
Say its bound is max{a_{n+1}, M}.
"Bounded" might mean bounded below and above. If it means that in the problem, you should also do the workd for "bounded below".
Great stuff. solved. Thanks!
