Calculating Speed at Top of Vertical Circle
The discussion revolves around calculating the minimum speed required for a ball attached to a cord to maintain tension while rotating in a vertical circle. The problem involves concepts from mechanics, specifically centripetal force and gravitational force.
  • Participants discuss the use of a free-body diagram to analyze forces acting on the ball at the top of the circle. There is an attempt to derive a formula for minimum speed, with some questioning the relationship between tension and gravitational force.
Some participants have provided guidance on the importance of considering the minimum speed and the conditions under which the tension in the cord becomes zero. There are multiple interpretations of the formula and calculations being explored, but no consensus has been reached.
Participants are encouraged to show their work and reasoning, indicating a focus on understanding the underlying principles rather than simply arriving at a numerical answer. There is an emphasis on the conditions at the top of the vertical circle.
kimikims
I'm not sure what formula to use on this?
A ball of mass 15.9 g is attached to a cord of
length 0.478 m and rotates in a vertical circle.
The acceleration of gravity is 9.8 m/s^2
What is the minimum speed the ball must
have at the top of the circle so the cord does
not become slack? Answer in units of m/s.
For all your questions, please show us what you have tried first. Begin with a free-body diagram of the ball at the top of the circle.
V min = Square root [(Ms)(g)(R)]
=Square root (15.9)(0.478)(9.8)
=Square root (74.48196)
=8.63 m/s ?
Now, remember...this is minumum speed...
...so the tension of the string is mimumum, or zero when the ball is at the top of its path (thus, only the force of gravity would equal the centripetal force.)
With this knowledge, draw a free body diagram of the ball when it is on the top of the path...
So would it be the square root of the radius times gravity?
= square root (0.478)(9.8)
= 2.16 m/s^2 ??
  • · Replies 16 ·
  • · Replies 38 ·
