What is the method for finding the mid-line of two parallel slopes?
  • Context: High School
  • Thread starter Thread starter Windseaker
The discussion revolves around the method for finding a line that is equidistant from two parallel slopes. Participants explore both geometric and algebraic approaches to determine this "middle slope line" between the two given lines.
  • Some participants seek clarification on whether the goal is to find a third line that is parallel and equidistant from the two existing lines.
  • One participant suggests using the x or y intercepts of the lines defined by the equation ax+by+c=0.
  • Another participant emphasizes the need for an average line between two slightly different parallel lines, proposing that the average of the y-intercepts can be used to find the midpoint.
  • One participant proposes taking the midpoint of the endpoints of both lines and using the slope formula to derive the slope of the middle line.
  • Another participant offers a geometric approach, suggesting constructing a perpendicular line at any point on one of the given lines to find points on the middle slope line.
  • Algebraically, it is noted that if one line is represented as y= mx+ a and the other as y= mx+ b, the middle slope line can be expressed as y= mx+ (a+b)/2.
Participants express varying interpretations of what constitutes the "middle slope line," leading to multiple competing views on the method to find it. The discussion remains unresolved, with no consensus on a singular approach.
Some assumptions regarding the definitions of the lines and the context of "middle" may not be explicitly stated, leading to different interpretations of the problem.
Windseaker
I have a question:
If you have two slope lines that don't touch but are parallel, how do you find the middle slope line of the two?
Mathematics news on Phys.org
Do you mean a 3rd line that is parallel to the other two, and equidistant from them?
Consider that you can find the x or y intercept of any line ax+by+c=0.
sorry i did not explain correctly
I am trying to find a line ( an average line) between two sloping lines that are parallel (but are just a little different from each other). I am trying to find that mid or average of the two.
OK let me try this:
I have two median lines, but I need to find the median line of two median lines!
The average or middle of two parallel lines is exactly what I said, another parallel line but with the average value of the both. For example, at x=0, if the y intercept of the first line is 1 and the intercept of the second line is 3, then the average of the two will be 2=(1+3)/2
Windseaker said:
I have a question:
Take the midpoint of the endpoints to both lines. Then use the slope formula to find the slope. If needed, plug in a point on the line to solve for b.
The question is what do you mean by "find the middle slope line"?
Geometrically: At any point on one of the two given lines, construct the perpendicular to that line. Because the two given lines are parallel this will also be perpendicular to the second line. The midpoint of that perpendicular is a point on the "middle slope line". Finding two such points gives you the line.
Algebraically: If one line is given by y= mx+ a, then the second line must be y= mx+ b. The "middle slope line" is y= mx+ (a+b)/2.
  • · Replies 47 ·
  • · Replies 53 ·
