Is the use of the malloc function in a subfunction causing warnings?
  • Thread starter Thread starter nenyan
The discussion revolves around the use of the malloc function in a subfunction within a C program, specifically addressing warnings related to incompatible implicit declarations of the built-in functions 'malloc' and 'free'. Participants explore whether these warnings are significant despite the code functioning correctly.
  • One participant reports receiving warnings about incompatible implicit declarations of 'malloc' and 'free' when using them in a subfunction.
  • The same participant questions the significance of these warnings since the code appears to work well.
  • Another participant suggests using Google search as a potential resource for troubleshooting.
  • A later reply indicates that the warnings can be resolved by including the header file , which contains the necessary declarations for 'malloc' and 'free'.
Participants do not reach a consensus on the importance of the warnings, and multiple views regarding the resolution of the issue are presented.
The discussion does not address the implications of not including or the potential consequences of ignoring the warnings.
nenyan
I use function malloc in a subfunction. then I got warrnings:
incompatible implicit declaration of built-in function 'malloc'
incompatible implicit declaration of built-in function 'free'
The code works well. Is it matter?
Code:
#include <stdio.h>
#include <math.h>
int min_in(double *a, int n)
  int i, min_i;
  double t;
  t=a[0];
  min_i=0;
  for(i=1;i<n;i++)
    if (t>a[i])
      t=a[i];
      min_i=i;
  return min_i;
void fourweight (int *a, double *b, int n)
	int i, k;
	double *c;
	if ( !(c=(double *)malloc(n*sizeof(double))) )
printf("memory error\n");
	for(i=0;i<n;i++)
		c[i]=b[i];
	for(i=0;i<4;i++)
	{k=min_in(c,n);
	a[i]=k;
	c[k]=10000.0;
free(c);
int main()
	int i, a[4]={0,0,0,0};
	double b[10]={0.1, 0.2, 0.3, 0.5, 0.11, 0.21, 0.31, 0.9, 1.1, 0.01};
fourweight(a, b, 10);
for (i=0;i<4;i++)
printf("%d, ", a[i]);
Technology news on Phys.org
Borek said:
Have you tried Google search? It often helps.
thank you
In case you haven't already figured it out, you need to #include <stdlib.h> for the declarations of malloc and free.
  • · Replies 36 ·
13K
  • · Replies 17 ·
