Question on finding inductance of parallel plate transmission line.
The inductance per unit length of a parallel plate transmission line, where the width (w) is significantly greater than the spacing (d) between the plates, is calculated using the formula L = μ₀(d/w). This calculation considers only one plate, leading to the question of whether the total inductance should be doubled to account for both plates. However, the established understanding is that the inductance is inherently defined for the entire configuration, and thus does not require multiplication by two. This principle also applies to capacitance calculations for parallel plate transmission lines.
  • Understanding of electromagnetic theory, specifically Maxwell's equations.
  • Familiarity with inductance calculations in transmission lines.
  • Knowledge of boundary conditions in electromagnetic fields.
  • Basic principles of parallel plate capacitors and inductors.
  • Study the derivation of inductance for parallel plate transmission lines in detail.
  • Explore the implications of the assumption w >> d on electromagnetic field uniformity.
  • Research the relationship between inductance and capacitance in parallel plate configurations.
  • Learn about the application of boundary conditions in electromagnetic field calculations.
Electrical engineers, physicists, and students studying electromagnetic theory, particularly those focusing on transmission line design and analysis.
yungman
Find the inductance per unit length of parallel plate tx line width = w and space =d between the two plates. w>>d.
My question is whether the total inductance is twice the calculate inductance because total inductance is the sum of inductance of the top and the bottom plate. But it seems all books only use one side for calculation. This is my calculation of the bottom plate only.
For w>>d, B is consider uniform and parallel to the plates.
I use the boundary condition of lower plate:
[tex]\int_s \nabla \times \vec B \cdot d \vec s = \int_c \vec B\cdot d\vec l = \mu_0 I[/tex]
I take medium 1 is space between the plates and medium 2 be the copper of bottom plate. [itex]\hat T_1[/itex] is same direction as B1.
[tex]\Rightarrow \int_c \hat T_1 \cdot ( \vec B_1 - \vec B_2) dl = \mu_0 I[/tex]
[tex]\vec B_2 = 0 \;\Rightarrow B_1= \frac {\mu_0 I}{w}[/tex]
[tex]\Phi = \int_s \vec B \cdot d\vec s = \mu_0 \frac {d I }{w} \;\hbox { for unit length =1 }[/tex]
[tex]L = \frac {\Phi}{I} = \mu_0 \frac d w[/tex]
I thought this is inductance of only one plate. The total inductance of the parallel plate is twice of the calculation. Why don't I have to multiply by two?
Thanks
Anyone?
I understand that in order to make the assumption of uniform field, you need both plates and w>>d. So it is not as if you can calculate the inductance totally separate. But still what ever your inductance calculation is, it apply on the other side.
This question is true when calculating capacitance of the parallel plate tx line also using electric boundary condition also( normal boundary ).
