Wood block coeffiecent of friction
The discussion focuses on calculating the distance a wooden block travels up an incline and its speed upon returning, given a coefficient of friction of 0.3 and an initial speed of 6 m/s on a 25-degree slope. The calculations involve applying Newton's second law and energy conservation principles, leading to a distance of approximately 2.52 meters up the incline and a height of 1.065 meters. The energy approach without friction yields a height of 1.83 meters, highlighting the significant impact of friction on the block's motion.
  • Understanding of Newton's second law of motion
  • Familiarity with the concepts of kinetic and potential energy
  • Knowledge of vector components in physics
  • Basic proficiency in trigonometry, particularly sine functions
  • Study the effects of friction on inclined planes in physics
  • Learn about energy conservation in mechanical systems
  • Explore advanced applications of Newton's laws in real-world scenarios
  • Investigate the role of coefficients of friction in various materials
Physics students, educators, and anyone interested in understanding the dynamics of motion on inclined planes, particularly in the context of friction and energy conservation.
Frosty_TAW
I also need help with this problem, it involves energy and i just can't crack the problem by using what i know, i can't even start it, so here it is:
A wooden Block whose intitial speed is 6 m/s starts to slide up an incline plane at 25 degrees above the horizontal.
a)if the coeffiecent of friction is .3 how far up the plane does the block go?
b) what will be the blocks speed after it has slid back down the plane to its starting point?
a)the energy way is this but i think that assumes no friction
[tex]\frac{v^2}{2g} = h[/tex]
u have to add up all the forces on the block [tex]|ma| = |F_g + F_f + N|[/tex]
which if u know vectors i think gives...
[tex]a = 7.15 \frac{m}{s^2}[/tex] down the slope
so the block makes it v = v_0 + at, 0 = 6 - 7.15 t, t = 0.84s and therefore
x = 6(.84s) - 1/2 (7.15) (.84s)^2 = 2.52 m which is the hypotenus
h = 2.52m sin 25 = 1.065 m so you i put a lot of round off error so check it out
(the energy equation yeilds h = 1.83 m so without the friction its off 58%!)
b) just make sure u account for the friction on the way down
thanks man, that helps a lot
  • · Replies 33 ·
  • · Replies 20 ·
