Fanno and Rayleigh Flow, calculating exit conditions
This discussion focuses on the application of Fanno and Rayleigh flow equations to determine exit conditions from known inlet parameters. The equations provided include relationships for pressure, density, temperature, velocity, and stagnation pressure, all expressed in terms of Mach number (M) and specific heat ratio (γ). The user seeks clarification on the interpretation of star quantities, which represent conditions at sonic flow (M=1), and how to utilize inlet conditions such as P_0, T_0, and M_0 to calculate exit conditions effectively.
  • Understanding of compressible flow principles
  • Familiarity with Fanno flow and Rayleigh flow equations
  • Knowledge of thermodynamic properties and their relationships
  • Basic proficiency in fluid dynamics and Mach number concepts
  • Study the derivation and application of Fanno flow equations in detail
  • Learn how to interpret and utilize Rayleigh flow equations for thermal analysis
  • Explore tables of thermodynamic properties for various gases at different conditions
  • Practice calculating exit conditions using example problems involving Fanno flow
Students and professionals in aerospace engineering, mechanical engineering, and fluid dynamics who are involved in analyzing compressible flow systems and need to calculate exit conditions from inlet parameters.
roldy
I've seen equations for Fanno flow and Rayleigh flow but I am confused on how to use them properly.
Fanno Flow
[tex] \frac{P}{P^{*}}=\frac{1}{M}\frac{1}{\sqrt{\left(\frac{2}{\gamma+1}}\right)\left(1+\frac{\gamma-1}{2}M^2\right)}[/tex]
[tex] \frac{\rho}{\rho^{*}}=\frac{1}{M}{\sqrt{\left(\frac{2}{\gamma+1}}\right)\left(1+\frac{\gamma-1}{2}M^2\right)}[/tex]
[tex] \frac{T}{T^{*}}=\frac{1}{\left(\frac{2}{\gamma+1}\right)\left(1+\frac{\gamma-1}{2}M^2\right)}[/tex]
[tex] \frac{U}{U^{*}}=M\frac{1}{\sqrt{\left(\frac{2}{\gamma+1}}\right)\left(1+\frac{\gamma-1}{2}M^2\right)}[/tex]
[tex] \frac{P_0}{P_0^{*}}=\frac{1}{M}\left[\left(\frac{2}{\gamma+1}}\right)\left(1+\frac{\gamma-1}{2}M^2\right)\right]^{\frac{\gamma+1}{2(\gamma-1)}}[/tex]
[tex] T_0=T_0^{*}[/tex]
Inlet conditions:
[tex]P_0=101325[/tex] Pa
[tex]T_0=288[/tex] K
[tex]M_0=0.1[/tex]
[tex]Area=0.1 m^2[/tex]
[tex]T_{wall}=3000[/tex]K
Friction Coefficient([tex]C_f[/tex])=0.2
Duct Length=10 m
Adiabatic, no work interaction, constant area
I guess my confusion comes from the * parameters. If I know my inlet conditions only, how can I calculate the exit conditions from these equations? What do the numerator parameters represent? Are they the values at the exit? The Mach number in these equations, are they any the given Mach number (in this case 0.1)?
The star quantities just represent the pressure at sonic condition (M = 1). It is just a reference condition. If you had, for example, [itex]p_{1}[/itex] and wanted [itex]p_{2}[/itex], you would simply do:
[tex]p_{2} = \frac{p_2}{p^*}\frac{p^*}{p_1}p_1[/tex]
You can generally find those values in tables or just calculate them directly if you wish.
  • · Replies 21 ·
