Integral of holomorphic function in 2 variables is holomorphic
The discussion centers around the holomorphic properties of the integral of a function defined in two variables, specifically the integral of a holomorphic function in the context of complex analysis. Participants explore the conditions under which the integral is holomorphic, referencing Morera's theorem and related theorems.
  • The original poster (OP) defines a contour integral \( I_\rho(s) \) and claims it is holomorphic on \( \mathbb{C} \) under certain conditions, seeking assistance in proving this.
  • Some participants suggest that the holomorphic nature of \( I_\rho \) may follow from Morera's theorem, which requires the function to be bounded on every disc.
  • There is a discussion about whether the conditions stated in the OP's notes imply that the hypotheses of Morera's theorem are satisfied.
  • One participant points out that the integrand \( g(s, z) \) is holomorphic in both variables where defined, but questions remain about the implications of the uniform bound property.
  • Another participant clarifies that the OP's goal is to show that the mapping \( (\rho, s) \mapsto I_\rho(s) \) is holomorphic, not just \( I_\rho \) for fixed \( \rho \).
  • Concerns are raised about the definition of \( g \) being undefined at the origin, although the contour does not pass through it, suggesting that this may not be an issue.
  • There is a reiteration of the need for clarity regarding the conditions under which the OP wishes to prove holomorphicity.
Participants express differing views on the applicability of Morera's theorem and the conditions necessary for proving holomorphicity. There is no consensus on whether the OP's conditions are sufficient to establish that \( I_\rho \) is holomorphic.
Participants note that the discussion involves assumptions about the boundedness of the function and the properties of the contour integral, which may not be fully resolved. The implications of the integral's behavior as \( \rho \) varies are also under consideration.
Giraffro
Define [tex]\forall \rho \in (0,\pi), C_\rho[/tex] to be contour traveling from [tex]+\infty + \pi i/2[/tex] to [tex]\rho i[/tex], then a semicircle to [tex]-\rho i[/tex] then a straight line to [tex]+\infty -\rho i[/tex]. Also define:
[tex]I_\rho : \mathbb{C} \to \mathbb{C}, s \mapsto \int_{C_\rho} \frac{z^{s-1}}{e^z - 1} dz[/tex]
I've shown that this function is well-defined, independent of the value of [tex]\rho[/tex] and [tex]\forall \rho \in (0, \pi), \forall s \in \mathbb{C}[/tex] with [tex]\Re(s) > 1, I_\rho(s) = (e^{2 \pi i s} - 1) \Gamma(s) \zeta(s)[/tex] - This is part of a proof of the functional equation for the Riemann zeta function in my lecture notes. However, my notes claim I can show that [tex]I_\rho[/tex] is holomorphic on [tex]\mathbb{C}[/tex] by showing [tex]\forall R > 0, \exists M > 0[/tex] such that [tex]\forall s \in \mathbb{C}[/tex] with [tex]|s| \leq R[/tex]:
[tex]\int_{C_\rho} \left| \frac{z^{s-1}}{e^z-1} \right| dz \leq M[/tex]
I can't find a reference that shows this gives you a holomorphic function.
Can anyone help?
I may be mistaking, but doesn't this follow from Theorem[/url]? If f is bounded on every disc, then I guess its integral over every closed curve must vanish.
Edit: Misread you're article and thought it was referring to the reverse implication AKA Cauchy's residue formula.
I was suggesting that the claim of your notes implies that the hypotheses of Morera's theorem are satisfied. Forget about your I_\rho for a moment; we are trying to prove the following:
Suppose [itex]f:\mathbb{C}\to \mathbb{C}[/itex] has the property that [tex]\forall R > 0, \exists M > 0[/tex] such that [tex]\forall s \in \mathbb{C}[/tex] with [tex]|s| \leq R, |f(s)| \leq M[/tex]. Then f is holomorphic.
Suppose [itex]f:\mathbb{C}\to \mathbb{C}[/itex] has the property that [tex]\forall R > 0, \exists M > 0[/tex] such that [tex]\forall s \in \mathbb{C}[/tex] with [tex]|s| \leq R, |I_\rho(s)| \leq M[/tex]. Then f is holomorphic.
I don't know whether you caught the edit, but I misread you're article and I've updated my OP to a stronger condition. I'm not particularly worried about the bound since I have one, so the claim I suppose we're trying to prove is:
If [tex]g : \mathbb{C}^2 \to \mathbb{C}[/tex] is holomorphic in both variables and define:
[tex]f : \mathbb{C} \to \mathbb{C}, s \mapsto \int_C g(s, z) dz[/tex]
If [tex]\forall R > 0, \exists M > 0 : \forall s \in \mathbb{C}[/tex] with [tex]|s| \leq R[/tex]:
[tex]\int_C |g(s, z)| dz \leq M[/tex]
then [tex]g[/tex] is holomorphic.
The OP still seems to ask something else than the above:
Giraffro said:
However, my notes claim I can show that [tex]I_\rho[/tex] is holomorphic on [tex]\mathbb{C}[/tex] by showing (...)
So you agree that [itex]I_\rho:\mathbb{C}\to \mathbb{C}[/itex] is holomorphic for every \rho? But you want to show that in fact
[tex]\mathbb{C}^2\to \mathbb{C}[/tex]
[tex](\rho,s)\mapsto I_{\rho}(s)[/tex]
is holomorphic?
is holomorphic?
No, the z and s variables coincide with the integrand in the definition of [tex]I[/tex], which is independent of [tex]\rho[/tex]. So here, [tex]g : \mathbb{C}^2 \to \mathbb{C}, (s, z) \mapsto z^{s-1} / (e^z - 1)[/tex]. Actually just noticed this is undefined at the origin, but our contour doesn't pass through it, so we should be okay. In any case, [tex]g[/tex] is holomorphic in both [tex]s[/tex] and [tex]z[/tex], where it's defined. My notes claim that [tex]I_\rho[/tex] is holomorphic because the uniform bound property I stated holds, but I don't see why it follows.
There still seems to be miscommunication. You probably made a typo in the last sentence of your previous post, where you say you want to show that g is holomorphic. So my understanding is that you DO want to prove that, for every rho, I_rho is holomorphic. Yes? Please be clear about this.
If so, I stand by my very first reaction, because the change you made in the OP is only a weaker condition:
if
then certainly
[tex]|I_\rho(s)| \leq M[/tex]
by the triangle inequality for integrals. So then we're back at post 4 where I suggest that I_\rho satisfies the hypothesis of Morera's Theorem.
  • · Replies 21 ·
