How Does the Angle of Impact Affect the Depth of Meteorite Craters?
  • Context: Undergrad
  • Thread starter Thread starter McHeathen
    Angle Impact
The discussion revolves around how the angle of impact affects the depth of meteorite craters, considering factors such as the mass, speed, and acceleration of the meteorite, as well as the influence of the Earth's rotation. The scope includes theoretical and conceptual aspects of impact dynamics.
  • Some participants claim that the angle of impact, along with mass and speed/acceleration, are factors influencing crater depth, questioning the relative importance of these factors.
  • One participant argues that while the impact angle affects the shape of the crater and debris distribution, the primary factors for crater depth are the speed and mass of the object.
  • Another participant asserts that the Earth's rotation does not affect the angle of impact, which is determined solely by the approaching object.
  • A participant discusses the theoretical scenario where if the Earth were not rotating, the angle of impact would be 90 degrees to the surface, but questions how rotation might alter this angle.
  • Some participants agree that the relative velocity of a meteorite compared to the Earth's rotational speed is significant, noting that the orbital velocity of Earth is much greater than its rotational speed.
  • One participant acknowledges a misunderstanding regarding the meteor's speed, realizing that the incoming speed is considerably higher than the Earth's rotational speed.
Participants express differing views on the influence of the angle of impact and the Earth's rotation, indicating that multiple competing perspectives remain without a clear consensus.
Discussion includes assumptions about the relative velocities involved and the conditions under which the angle of impact is considered, but these remain unresolved.
McHeathen
The angle of impact along with the mass and speed/acceletation have been claimed to be factors responsible for the depth of a crator. How importat a factor is the angle of impact? are the mass and speed/acceleration more important factors?
How much influence will the Earth's rotation have on the angle of impact?
Astronomy news on Phys.org
The major factors in crater depth would be the speed and mass of the object. The impact angle would affect the shape of the crater and things like distribution of debris.
The Earth's rotation could not have any effect on the angle of impact. That is determined by the approaching object.
If the Earth were not rotating and the meteor moved toward the center of the Earth, the angle of impact is 90 degrees to the surface (or, rather, to the tangent to the surface at that point). But if the Earth were rotating, wouldn't that be equivalent to the meteor landing with a velocity equal to the vector sum of the vertical speed and the Earth's tangential velocity? That wouldn't be directed at 90 degrees to the surface, would it?
Fewmet is right. Because the Earth is fairly small and rotates fairly slowly, though, the relative velocity of a rock in space and Earth (roughly of order of the orbital velocity of earth) is much bigger than the rotation velocity of Earth on the equator (where it is biggest). So although in theory you should add the two, in practice you dont; have to.
Good point: I was thinking of the meteor's speed being from falling, and overlooked the obviously large orbital velocity of the Earth. Thanks for the clarification.
the speed of the incoming meteor is quite considerable 20 to 40 km / Sec or so, considerably faster than the rotational speed of the earth
Dave
  • · Replies 17 ·
  • · Replies 41 ·
