Oxidation using selenium dioxide
  • Thread starter Thread starter maverick280857
    Oxidation
The discussion revolves around the oxidative function of selenium dioxide (SeO2) when reacted with carbonyl compounds, specifically focusing on the reaction of butan-2-one. Participants explore the mechanistic pathways and product formation, including the major and minor products resulting from the reaction.
  • Vivek questions why butan-2-one reacts with SeO2 to form two products, seeking a mechanistic explanation for the predominance of one product over the other.
  • One participant suggests that terminal methyl groups are more vulnerable to SeO2 attack compared to the more shielded ethyl group's alpha methylene, indicating a structural basis for product formation.
  • Another participant mentions that the more hindered side of butanone is oxidized more frequently, proposing a connection to the stability of the enolate formed during the reaction.
  • Corey’s proposed mechanism involves the formation of selenous acid, followed by a series of steps including enolization and a 2,3 shift, leading to the final products.
  • Sharpless offers an alternative mechanism where the enolate first attacks selenium, leading to a C-Se bond formation, followed by further enolization and potential formation of a three-membered ring intermediate.
  • Participants discuss the kinetic and thermodynamic factors influencing the formation of the major and minor products, including the nature of carbanion formation from the methylene and terminal methyl groups.
Participants express differing views on the mechanisms and factors influencing product formation, indicating that multiple competing models remain without a clear consensus on the correct pathway.
There are limitations regarding the assumptions made about the mechanisms, the dependence on specific reaction conditions, and the unresolved details of the proposed mechanistic steps.
maverick280857
Hello
My question is regarding the oxidative function of selenium dioxide (when reacted with carbonyl compounds).
Selenium Dioxide converts an active methylene group to a carbonyl group -C=O, so the reaction of butan-2-one with selenium dioxide should form two products (corresponding to two active methylene groups):
2MeCOEt + SeO2 -> MeCOCOMe + HCOCOEt + Se
I know that MeCOCOMe is the Major Product whereas HCOCOEt is the minor product but I want to know why this is so. Perhaps a mechanistic explanation may help. I have been unable to locate the exact mechanistic steps of this reaction. I only know that SeO2 delivers nascent oxygen.
Help would be greatly appreciated.
Thanks and cheers
Vivek
Chemistry news on Phys.org
Don't try to find the solution far away; the solution is right in the structure. Terminal methyl groups are more vulnarable to selenium dioxide attack than partly shielded ethyl group's alfa methylene. It is possible though, some product is formed with the action of SeO2.
But what Maverick said is that the more hindered side is oxidized more often.
I think that it has to do with the more stable enolate of butanone.
Corey has proposed a mechanism that begins by forming selenous acid by adding a water molecule to the SeO2, then the ketone oxygen attacks the selenium displacing a water molecule. The activated carbonyl can then enolize. The oxidation step is though to be a 2,3 shift, where one of the remaining oxygens on selenium attacks the enol double bond forcing the electrons of the enol back into the carbonyl and then forcing the electrons from the Se-O bond onto selenium (so selenium is reduced). The final step is deprotonation of the carbon bearing the O-Se-OH group to form either Se(OH)2 or selenium zero and two water molecules.
Sharpless has proposed a different mechanism where you form the enolate first and then the enolate attack the selenium of selenous acid to make a C-Se bond. Then he proposes that the carbonyl group is again enolized, but this time instead of protonating again the electrons from the enol form a double bond to selenium and eject a water molecule off of the selenium to give a species that looks sort of like this: O=C-C=Se=O . This species can give the product by attack of water at the carbon of the C=Se bond to form the ketone, selenium zero, and a water molecule after some electron pushing. Sharpless also mentions the posibility that the oxygen of the Se=O could attack the carbon of the C=Se bond to make a three membered ring that could fragment open to give the product and selenium zero.
Are those mechanistic explanations clear? I might be able to make up a pictoral representation of that if you want.
Here are the references, if you're interested:
Corey, J. Am. Chem. Soc. 1960, 82, 917
Sharpless, J. Am. Chem. Soc. 1976, 98, 300
Oops, you are right, Movies. Thanks for the references, and Maverick, if you need these, I can get them for you as my library has a subscription to American Chemical Society.
Movies, you are right about that more stable enolate is formed principally (and thermodynamically) but the side product may be explained with kinetic easiness of the reaction. I've reviewed it and methylene forms a secondary carbanion where terminal methyl forms a primary one.
And I realize that trying to contribute to the forum while exhausted does not produce useful results.
Yep, the minor product could be explained by kinetic enolate formation.
  • · Replies 28 ·
  • · Replies 19 ·
11K
