Set theory proof - counter examples
The discussion revolves around providing counterexamples to disprove a set theory statement, specifically the equation A - (B U C) = (A - B) U (A - C). Participants explore methods for finding counterexamples, including the use of Venn diagrams and different set configurations.
  • One participant questions how to determine counterexamples and suggests using Venn diagrams to visualize the differences between the left-hand side (LHS) and right-hand side (RHS) of the equation.
  • Another participant proposes a method of selecting sets A, B, and C to demonstrate that the LHS does not equal the RHS, expressing uncertainty about the necessity of using an empty set for C.
  • A later reply indicates that while A = B = {a} and C = {c} is a valid counterexample, it may not be the simplest one.
  • Participants discuss the validity of different configurations for A, B, and C, suggesting alternatives such as A = C = {a} and B = Ø, and affirming that multiple approaches can be acceptable.
Participants generally agree that there are multiple valid methods for finding counterexamples, but there is no consensus on the necessity of simplicity in the examples provided. The discussion remains open regarding the best approach to take.
Participants express varying degrees of comfort with using Venn diagrams and different set configurations, indicating a range of understanding and preferences in methods for disproving statements in set theory.
amp92
I'm having a problem with providing counter examples when disproving a statement. For example A - (B U C) = (A - B) U (A - C). The solution given was A = {a}, B = {a} and C = empty set.
My question is how can you work this out - i was told it's possible from the Venn diagrams but I'm not sure how this works. My method to find counter examples is usually to make A = {a}, B = {b} and C = {c} and then show the LHS doesn't equal the RIGHT. If it does i make changes to either A,B,C (i.e. use empty sets etc.). So for the example above can't you have A = {a}, B = {a} and C = {c}. How do you know C is an empty set?
Is it ok to stick with my method or can someone explain how to use the Venn diagrams for the LHS and RHS to find the counter examples.
Thank you :)
Thank you :)
Here's a picture of the corresponding Venn diagrams.
As you can see the diagrams are different in both cases.
In particular, if A ∩ B contains an element that is not part of C, we have a situation where the difference shows.
Let's say A ∩ B = {a} and {a} ⊄ C.
Then the simplest case of this would be if A=B={a} and C=Ø.
Ok i think i understand - you could have A=B={a} and C = {c} but it wouldn't be the simplest answer?
Also could you do exactly what you did for A ∩ B for A ∩ C instead as an alternative answer so the counter example would be A=C={a} and B = Ø?
Thank you so much for taking the time to explain this and for the diagrams :)
Yes, but your solution is fine too!
The counter example does not have to be the simplest possible, it just needs to do the job.
Of course, as a purist mathematician, I tend to search for the simplest most elegant solution.
Yes, that works just the same. :smile:
  • · Replies 18 ·
  • · Replies 18 ·
