What do the subscripts in thermodynamic steam tables mean?
  • Context: Undergrad
  • Thread starter Thread starter AriAstronomer
    Steam Thermodynamic
The subscripts in thermodynamic steam tables represent specific enthalpy components: hf (enthalpy of saturated liquid), hg (enthalpy of saturated vapor), and hfg (latent heat of vaporization). The total enthalpy (h) of a system is calculated using the formula h = hf + x * hfg, where x is the quality of the steam. Understanding these components is crucial for analyzing two-phase systems, commonly referred to as wet steam, in thermodynamic applications.
  • Understanding of thermodynamic principles, specifically phase changes.
  • Familiarity with steam tables and their applications in engineering.
  • Knowledge of enthalpy and its significance in thermodynamics.
  • Basic grasp of the concept of quality in two-phase systems.
  • Study the derivation and application of the Clausius-Clapeyron equation.
  • Learn about the properties of saturated and superheated steam.
  • Explore the use of steam tables in real-world engineering problems.
  • Investigate the impact of pressure and temperature on steam properties.
Engineers, thermodynamicists, and students studying mechanical engineering or energy systems will benefit from this discussion, particularly those focusing on steam systems and phase change analysis.
AriAstronomer
Hey everyone,
I'm a bit confused with the meanings of f, g, and fg subscripts in the thermo steam tables (e.g. hf, hfg, hg). If there is saturated steam, part of the enthalpy is in liquid, hf, part is encapsulated in the vapour, hg, but what is hfg? Also h = hf + (x)hfg. h here is the total enthalpy of the entire system, and hf/hfg are the components?
Another question, is what is the difference between saturated liquid water, and saturated steam?
Some general help would be appreciated.
Ari
Science news on Phys.org
Here is a quick rundown.
You should be aware that engineering steam is usually a 2 phase system ie both liquid and gaseous water are present. this is also called wet steam.
Starting with a pot of liquid water not in equilibrium with vapour (steam) we need to add energy to it to bring it to saturation (equilibrium with vapour)
This energy is the enthalpy hf kJ/kg at any temperature tf
Once we have the water in equilibrium we want to evaporate it so we have to add the latent heat or 'specific enthalpy of evaporation' hfg again inkJ/kg.
this energy is added at constant (saturation) temperature tf.
We now have our water as dry, saturated vapour. To get our water to this stage, we must have added the vapour specific enthapy hg - you guessed it in kJ/kg.
So hg = hf + hfg.
If we wish to heat this dry steam further we must add the superheat enthalpy.
The superheat enthalpy is the gaseous specific heat Cp times the temperature difference, as with any other gas.
hs = Cp(Ts - Tf) kJ/kg
Where T is in degrees Kelvin.
The total enthalpy of the gas is then
h = hs + hg
Hope this helps
go well
thanks a lot for the speedy reply, it definitely cleared a lot of things up.
  • · Replies 19 ·
