Is There an Easier Way to Understand Polynomial Inequalities?
  • Context: High School
  • Thread starter Thread starter Pseudo Statistic
    Inequalities Polynomial
The discussion revolves around understanding polynomial inequalities, specifically methods for solving them and the reasoning behind different approaches. Participants explore various techniques, including the use of test points and sign analysis on a number line, while expressing uncertainty about the clarity and effectiveness of these methods.
  • One participant questions the use of test points in determining the nature of polynomial inequalities, suggesting that if the test point satisfies the inequality, it indicates a conjunction, while if it does not, it indicates a disjunction.
  • Another participant explains that the product of two factors is positive when both are either positive or negative, providing a logical breakdown of the conditions for the inequality (x+2)(x-4) > 0.
  • A different participant expresses confusion about the method described and seeks validation for their own approach using test points.
  • One participant suggests that identifying points where factors equal zero can help in testing intervals between these points to determine the sign of the polynomial.
  • Another participant emphasizes that a polynomial must change sign at the roots and discusses how to test intervals defined by these roots to determine where the polynomial is positive or negative.
Participants express varying levels of understanding and agreement on the methods discussed. Some participants find the test point method valid, while others prefer a more logical breakdown of the conditions. Overall, there is no clear consensus on which method is easier or more effective.
Participants mention different methods and reasoning without resolving the effectiveness or simplicity of each approach. The discussion reflects a range of understanding and assumptions about polynomial inequalities.
Students learning about polynomial inequalities, educators seeking to understand student perspectives on teaching methods, and individuals interested in mathematical reasoning and problem-solving techniques.
Pseudo Statistic
We just started these at school, but I have some questions..
Inequalities on number line (x) graphs..
Using x = 0 testpoint..
Let's say I have (x+2)(x-4) > 0, (0 + 2)(0 - 4) would be -8, and -8 !>0, so it would be a disjunction, right? But if it was positive and satisfied the inequality, it would be a conjunction, right?
OR what if it was < 0 instead, if it satisfied it would be a disjunction and if it didn't satisfy it would be a conjunction, right?
And let's say I have x(x-2)(x+4) > 0, the teacher taught us this method where we plot -4, 2 and 0 on a number line and place positive signs and negative signes over each one accordingly so that the satisfying inequality would be where the 3 signs ontop of each other would be + or -, according to the inequality...
IS there an easier way to do this?
I'm sorry that I don't make much sense, I'm in a hurry...
Hope someone can make sense of my words and help!
Thanks.
there are ways ofcourse ... its simple logic most of the times ...
Anything greater than 0 indicates it is positive and anything less than 0 indicates it is negative ...
Now,
Take your example,
(x+2)(x-4)>0
This suggests to us that (x+2)(x-4) must be positive.
When is multiplication of two numbers positive?
we know that,
(negative)*(negative) = positive
(negative)*(positive) = negative
(positive)*(negative) = negative
(positive)*(positive) = positive
this suggests to us that,
either both (x+2) and (x-4) are positive
or both are negative
i.e (x+2)>0 and (x-4)>0
or
(x+2)<0 and (x-4)<0
x+2>0 implies x>-2
x-4>0 implies x>4
both of these conditions are true only if x>4
or
x+2<0 implies x<-2
x-4<0 implies x<4
both of these conditions are true only if x<-2
so u have the solution ...
I am not saying this is easier than the one proposed by your teacher (infact they are same). This infact is the wordy explanation of the method given by your teacher ... Can u see why??
-- AI
Heh, I still don't understand this method, but was curious if the one I had with the test point is right.
One good way to test such inequalities is to find the points where one of the factors goes to 0 (for (x-2)(x+3)<0, these are 2 and -3) and check a test point between each one.
One key point is that, if a polynomial is positive for x= x0 and negative for x= x1, then the value MUST BE 0 someplace between x0 and x1.
In particular, (x+2)(x-4)= 0 only at x= -2 and x= 4. Those two points divide the real number line into 3 intervals: x< -2, -2< x< 4, and x> 4. Since (x+2)(x-4) can CHANGE SIGN only at -2 and 4, it must have the SAME SIGN in each interval and it is only necessary to check on point in each.
Pick ANY number less than -2: -3 will work. (-3+2)(-3-4)= -1(-7)= +7> 0 so EVERY x< -2 makes (x+2)(x-4)>0.
Pick ANY number between -2 and 4: 0 is a simple choice. (0+2)(0-4)= 2(-4)= -8< 0 so EVERY x between -2 and 4 makes (x+2)(x-4)< 0.
Pick ANY number larger than 4: 5 is good. (5+2)(5-4)= 7(1)= 7> 0 so EVERY x> 4 makes (x+2)(x-4)> 0.
(x+ 2)(x- 4)> 0 for all x< -2 and x> 4.
