Anti-Gravity from Matter-AntiMatter Repulsion
  • Context: Graduate
  • Thread starter Thread starter sanman
    Anti-gravity Repulsion
The discussion revolves around the theoretical implications of matter and anti-matter interactions, particularly focusing on the concept of anti-gravity and its potential effects on the expansion of the universe. Participants explore various speculative applications, such as propulsion systems and the existence of anti-matter regions in the universe, while also questioning the gravitational behavior of particles and antiparticles.
  • Some participants propose that matter and anti-matter might repel each other, suggesting a form of anti-gravity that could explain the universe's expansion.
  • Others argue that matter and anti-matter attract each other gravitationally, challenging the notion of anti-gravity and questioning the feasibility of using matter-antimatter interactions for propulsion.
  • A participant references Massimo Villata's assumptions regarding the gravitational behavior of matter and anti-matter, suggesting that under certain conditions, anti-gravity could occur.
  • Concerns are raised about the gravitational behavior of particles that are their own antiparticles, such as photons and neutral pions, and how they might interact gravitationally.
  • Some participants express skepticism about the creation of Bose-Einstein condensates (BECs) from anti-hydrogen, questioning the conditions necessary for such experiments.
  • There is a discussion about the implications of general relativity being CPT invariant and how this might affect the understanding of gravitational interactions between matter and anti-matter.
Participants do not reach a consensus; multiple competing views remain regarding the gravitational interactions of matter and anti-matter, and the potential for anti-gravity effects. The discussion includes both speculative ideas and established theories, leading to ongoing debate.
Some claims depend on specific assumptions about the nature of mass and energy in gravitational contexts, and the discussion highlights unresolved questions regarding the behavior of particles and antiparticles in gravitational fields.
sanman
There's a theory being proposed that the reason for the expansion of the universe is because of the mutual repulsion of matter and anti-matter, in what is essentially anti-gravity:
http://www.universetoday.com/84934/...-dark-energy-as-cause-of-universes-expansion/
So just as a thought experiment - what if this was true? What if matter and anti-matter repel each other in what amounts to an anti-gravitational force?
Would there be any way to usefully harness this for propulsion purposes?
Could you make some kind of gravitational catapult from matter-antimatter repulsion?
Unlike EM force, whose influence falls off very quickly beyond short distances, your gravitational catapult would sustain its accelerative effect on you over a vast span of distance.
If your rocket is made of matter, and somehow has an equal mass of anti-matter attached to it, then is it effectively "gravitationally neutral"? (ie. like "buoyancy neutral")
Could you hover near the event-horizon of a black hole without too much effort, like in the Disney movie?
So just as conventional objects made of matter will fall downwards towards Earth, then would objects made of anti-matter "fall upwards"? (ie. away from our matter-based planet)
And just as another hypothetical speculation, what if this means that there are large islands of anti-matter waiting for us outside our galaxy? I know it sounds pie-in-the-sky to talk about traveling outside our galaxy, but how could we safely do so if we're in danger of running into some anti-matter and getting annihilated by it?
Also, if there are entire galaxies and solar systems out there composed of anti-matter, then could these potentially generate "anti-life" (ie. life composed of anti-matter)?
How do you communicate with life made of anti-matter?
These days we have BECs and atom lasers, which are supposed to be able to measure gravitational effects with great sensitivity while self-shielding from charge effects. I'd read that recently for the first time, a BEC had been briefly created from anti-hydrogen.
Since hydrogen and anti-hydrogen are each overall charge-neutral, that could help in focusing measurement on the gravitational behavior of anti-matter wrt to matter.
(This sounds like a job for some topnotch national lab to attempt such an experiment, using antimatter, BECs and high vacuum.)
If BECs and atom lasers already allow us to manipulate apparent mass properties using wave mechanics, and if we can apply these principles to matter-antimatter repulsive interactions, then couldn't similarly manipulate gravity/spacetime?
Matter and anti-matter still attract each other gravitationally, so that's no to most of your questions.
The article suggests it might be more complicated than this if we apply the http://www.lbl.gov/abc/wallchart/chapters/05/2.html of quantum field theory to gravity, I'd like to see what other physicists think of his argument though:
Massimo Villata, a scientist from the Observatory of Turin in Italy, began the study with two major assumptions. First, he posited that both matter and antimatter have positive mass and energy density. Traditionally, the gravitational influence of a particle is determined solely by its mass. A positive mass value indicates that the particle will attract other particles gravitationally. Under Villata’s assumption, this applies to antiparticles as well. So under the influence of gravity, particles attract other particles and antiparticles attract other antiparticles. But what kind of force occurs between particles and antiparticles?
To resolve this question, Villata needed to institute the second assumption – that general relativity is CPT invariant. This means that the laws governing an ordinary matter particle in an ordinary field in spacetime can be applied equally well to scenarios in which charge (electric charge and internal quantum numbers), parity (spatial coordinates) and time are reversed, as they are for antimatter. When you reverse the equations of general relativity in charge, parity and time for either the particle or the field the particle is traveling in, the result is a change of sign in the gravity term, making it negative instead of positive and implying so-called antigravity between the two.
Experiments related to the principle of equivalence already show that all known forms of energy have the same sign for gravitational purposes.
Also, particles such as the neutral pion and the photon are their own antiparticles. How would they behave?
Maybe they would be gravitationally neutral to one another (ie. no gravitational attraction or repulsion)
sanman said:
... I'd read that recently for the first time, a BEC had been briefly created from anti-hydrogen
Is this really true? I thought the temperature of the anti-hydrogen was too high for the BEC transition to take place. But sure, if a BEC of photons can be made, anti-hydrogen doesn't seem impossible, but if you have a reference I would be very interested.
From the http://cerncourier.com/cws/article/cern/30577"
"... Back down to the sober reality here at CERN, we would be happy just to demonstrate trapping of antihydrogen in principle. This means initially trapping just a few anti-atoms – not making a BEC or antihydrogen ice. ..."
That can't be right, because photons are also their own antiparticles, and we know that photons "fall" in the Sun's gravitational field; they are attracted to the Sun.
On consideration, that observation alone may be enough to scuttle the whole idea of antiparticles gravitationally repelling particles.
I thought it was already known that gravity being a spin-two field quantum mechanically was enough to show that it has to be always attractive? I seem to remember reading something like that in discussions of the research done on quantizing GR in the 1960's (among other places, I remember seeing something about it in the Feynman Lectures on Gravitation--unfortunately I don't have my copy handy to check).
I think this is somewhat reversed. The spin 2 classification for the graviton in low energy effective field theories of gravity is a result of assuming gravity is attractive only, not the other way around.
Impossible. Light has the same gravitational attraction as matter to better than 2%.
I don't get this. If GR is CPT invariant, why does that term change sign?
Heh, fancy seeing you here, Sanman, was just coming over to see what others thought.
The first thing that came to mind for me is the messed up way a gravity well would interact with a region with opposite curvature. My thoughts jumped immediately to the old Penrose diagrams of rotating black holes connecting universes and anti-universes.
Additionally, isn't P-symmetry just a reversal of one coordinate, (x, y, z) -> (-x, y, z), rather than (x, y, z) -> (-x, -y, -z)?
Hmm...I thought spin-2 for the graviton was a consequence of the fact that gravity requires a tensor theory; neither a scalar (spin-0) nor a vector (spin-1) theory can account for the low-energy phenomena. Again, I don't have references handy so I may be misremembering.
What I meant was that photons would be gravitationally neutral wrt each other, and not to matter. This was in reply to the comment that photons are their own anti-particles.
Are you saying that photons are gravitationally attracted to each other?
Okay, then maybe photons are attracted equally to matter and to antimatter. But that doesn't prove that matter and antimatter are attracted to each other.
It seems to me that the best way to answer this question is thru experimental measurement.
Unfortunately, charge interaction dominates between matter and antimatter at short distances. Perhaps the use of BECs and atom lasers at significant distances could then definitively show whether anti-particles attract or repel each other.
Anti-hydrogen is neutral.
Yes, it's charge-neutral, which is what would diminish any charge interaction between it and hydrogen across a distance. This would allow any gravitational interaction to stand out more.
Hmm, good point. I guess it depends on where you start from.
Cheers
But how does the gravity know that the interaction is between two photons instead of a photon and matter? Gravity couples to energy, and photon energy "looks just like" matter energy. (In fact, since atoms are held together by electromagnetic forces, a significant portion of the energy in matter is really energy of virtual photons anyway.)
Okay, how does a positive charge know it's interacting with a negative charge at a distance?
If charge can know, why can't gravity know? Whatever is at the root of why antimatter has opposite charge sign to normal matter, may help gravity to distinguish what it is coupling with.
It's still worth measuring how anti-matter behaves in a gravitational field. Our own Earth produces plenty of gravity, which should help us find out which way anti-matter will fall.
Because there are two kinds of charges (opposite signs), but only one kind of energy.
I agree completely that this is worth measuring. Unfortunately, the Earth's gravity is really weak, comparatively speaking, even though the Earth is a large object, so it's not as easy to measure as it might seem.
I'd still like to see where exactly in GR charge makes an appearance. Last I heard gravity didn't couple to the internal symmetry groups of the particles.
That CPT thing is non-sense. If you can show me where that "gravity term" is proportional to charge, fine.
In fact you don't even need to go to GR. Show me where charge appears in Newton's Law? Or is that wrong too now because one guy said so on a random website?
If you want to have an easier to imagine picture, try this: the positive charge emits virtual photons and the negative charge accepts virtual photons.
[PLAIN]http://www.kirksville.k12.mo.us/khs/Teacher_Web/alternative/electricfield.gif
Masses don't exchange virtual gravitons, they interact with the geometry of their local spacetime, and other masses interact with each other through their influence on local geometry.
Figure out how to draw one of these for gravity, in particular one for gravity with charges:
I think it's a little more complicated than that. The Usenet Physics FAQ has a good page on virtual particles and how they mediate forces:
http://math.ucr.edu/home/baez/physics/Quantum/virtual_particles.html
Also, since photons are their own antiparticles, there is no real difference between "emitting" and "accepting" one. With real photons, ones we actually observe, we can finesse this by decreeing that the earlier event is the "emission" and the later one is the "reception" of the photon, and since real photons go at the speed of light, which event is first is the same in all reference frames. But virtual photons don't have to move at the speed of light--they can go faster, or slower, and if they go faster, there is no frame-invariant way to say which event is first. That's why it's normally just said that virtual particles are "exchanged".
But from a quantum standpoint, the local spacetime geometry has to be quantized too, and when you try to do that, at least in the "obvious" way, you do get masses interacting by exchanging virtual gravitons. (I realize that is not a complete picture and there are a lot of issues in this area, which is why we still don't have a good quantum theory of gravity. But even in the current candidate quantum gravity theories, such as string theory, you still have virtual gravitons being exchanged--in string theory, they are among the simplest string states.) The difference is that, while there are positive and negative electrical charges, there is only one kind of "gravitational charge", since that is just energy, and the energy of gravitating objects is always positive--more precisely, the stress-energy tensor always satisfies what is called the "weak energy condition". (I think that's the right one--but experts, please correct me if I've misstated it.)
There is one exception to that generalization: "dark energy", which is energy associated with a cosmological constant, or, equivalently, associated with what we normally think of as "empty space". The stress-energy tensor of dark energy violates the weak energy condition, which is why dark energy can cause the universe's expansion to accelerate (a kind of "gravitational repulsion"). But dark energy has nothing to do with antimatter, and the special properties of its stress-energy tensor can't be possessed by the stress-energy tensor of any "normal" kind of substance, whether it's matter or antimatter (or light or anything else).
I think in theories of gravity we think of "charge". In the traditional theories (Newton) where gravity is a force we think of the "charge" as being mass in analogy to EM. This paper is equating this "charge" not to mass but to part of the energy/momentum 4 vector.
Well, as I said, I was trying to simplify the explanation to make it easier to see the difference.
I kept typing "exchanges" but decided to go with 'emits' and 'accepts' to try to get across the concept in a way which would let him build a more complex understanding later.
Well, I wouldn't call string theory a candidate quantum gravity theory, but my understanding is several years out of date, due to being unwilling to seriously accept certain assumptions in stringy models. I'd say it's just an interesting mathematical structure from which certain interesting results can be produced.
You can't perform renormalization on gravitons either.
The weak energy condition just requires that all observers find a non-negative energy density, which could be an argument against anti-gravity except others have found it doesn't preclude it by itself.
Indeed, I was trying to find a way to explain this, but you did it excellently.
Well, it certainly is in the minds of string theorists. :wink: As far as I know, though (which isn't terribly far), the other candidates (loop quantum gravity and spin networks are the ones I'm thinking of--there may be others) also have states that can be viewed as virtual gravitons.
True.
Can you elaborate on this? I thought the weak energy condition was sufficient to ensure that gravity is always attractive.
It's the other way around.
Positive energy leads to a stress energy tensor which can only produce attractive gravity.
The weak energy condition requires all observers find a non-negative energy density.
As for string theory, that's a matter for other threads, but I haven't heard of a manner to produce a background independent formulation, so it's just about the actors on the stage, without describing the stage itself in a manner that suits me.
Anyway, I think it would be worth it to try to achieve BECs and "atom lasers" made from antimatter, in order to test antimatter's behavior in our Earth's gravitational field.
What we really need to see is whether antimatter particles fall up or down in our Earth's gravity. It should be possible to definitively and conclusively discern this experimentally.
Repulsion of matter and antimatter is incompatible with general relativity (and in an absurdly nonlocal way). In my opinion there isn't any need to measure this, any more than there is to check that bananna-flavored taffy is described by GR (since we've only already checked for strawberry-flavored taffy).
Anti-matter has positive energy density. By the positive energy theorem, then, a spacetime continaing anti-matter has positive ADM energy. In particular if you make a spherical ball of antimatter, the solution outside is Schwarzschild of positive mass M. Now, it has been rigorously derived from Einstein's equation that a small body will move on a geodesic (see Geroch and Jang from the 70's or more recently Geroch and Ehlers); and since the mass M is positive, this constitutes an attraction. Thus, anti-matter attracts matter within general relativity. This is a proof.
If there was going to be a repulsion there would have to be an amazingly nonlocal interaction whereby one charge figures out what the other charge is made of, instead of just responding to the local spacetime metric.
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 31 ·
  • · Replies 22 ·
  • · Replies 34 ·
