Do Accelerated Charges Always Radiate?
  • Context: Graduate
  • Thread starter Thread starter shoestring
The discussion revolves around the conditions under which accelerated charges radiate, particularly focusing on the behavior of an electron and a proton accelerating together, and the implications for neutral matter. Participants explore various scenarios, including the formation of a hydrogen atom and the behavior of dipoles under acceleration.
  • One participant questions when accelerated charges radiate and when they do not, particularly in the context of neutral matter composed of charged particles.
  • Another participant suggests that the interaction of opposite charges may result in no net radiation due to their oppositely directed magnetic fields.
  • A different participant emphasizes the importance of the fields produced by the charges rather than the acceleration itself.
  • One participant asserts that a dipole will radiate if its dipole moment is not constant, discussing the conditions under which quadrupole radiation can occur.
  • Another participant elaborates on the mathematical relationships between multipole moments and their time derivatives, indicating that specific conditions must be met for radiation to occur.
Participants express differing views on the conditions for radiation from accelerated charges, particularly regarding dipoles and quadrupoles. There is no consensus on the overall question of when accelerated charges radiate.
Participants highlight the complexity of radiation conditions, including the dependence on the time variation of multipole moments and the nature of the acceleration applied to the charges.
shoestring
Assume two charges, an electron and a proton, accelerate together. For example, let them start at (x,y)=(0,h) and (0,-h) and move in the +x direction along parallel trajectories (x(t),h) and (x(t),-h) while accelerating.
If they are far apart I assume they will each radiate on its own, but what happens if they are close, or even combine to form a hydrogen atom? When will they stop radiating?
Any neutral piece of materia made up of electrons, neutrons and protons consists of charges, so why doesn't a neutral piece of materia radiate under acceleration?
In short: When do accelerated charges radiate and when don't they?
This is not my strongest area, but I think it is that opposite charges, when accelerated, will produce oppositely directed magnetic fields, so there is no net field. I am eager, though, to see comments from someone with a stronger background.
Thanks, that makes sense. What happens to the fields is perhaps more important than the acceleration of the charges itself.
A slightly different question: If a dipole is accelerated, will it radiate?
Yes, they will radiate. Although this is not obvious!
Let d be the position vector of the midpoint of the two particles, and h the vector from there to particle 1. The particles will be located at r1 = d + h and r2 = d - h. The dipole moment will be p = ∑ qi ri = e(d + h) - e(d - h) = 2eh. So what, you say? The point is that p is constant. You can't possibly get dipole radiation from the charges, since their dipole moment is constant.
Ok, now look at the quadrupole moment. Q = ∑ qi riri = e(d + h)(d + h) - e(d - h)(d - h) = 2e(dh + hd). So what, you say? The point is that Q is *not* constant. Since you can choose d(t) to be anything you like, Q can also be made to vary in time in any way you like. So in general you can get quadrupole radiation. But there's a condition that must be imposed on d(t).
E & M books are so quick to Fourier transform everything, it's hard to find a radiation formula that still has t dependence in it. In Jackson, for example, the radiated power of an oscillating dipole is given as P = ck4/3 |p|2. If he hadn't Fourier transformed it, this would have been P = c/3 |p(2)|2, where (2) means the second time derivative. A few pages later, the power from an oscillating quadrupole is given as P = ck6/360 |Q|2. Meaning P = c/360 |Q(3)|2. In general, the radiation formula for the mth multipole moment will have m+1 time derivatives on it.
The point here is that not just any time dependent p or Q will radiate. You need a p such that p(2) is nonzero. Likewise you need a Q such that Q(3) is nonzero. Solutions for which p ~ t or Q ~ t2 do *not* radiate. These are called nonradiative motions.
In the present problem, if you use a constant acceleration d(t) = at2/2, then Q(t) ~ d(t) ~ t2 is a nonradiative motion. You'll get quadrupole radiation if and only if the acceleration is not constant.
Great post Bill.
  • · Replies 36 ·
