How Do You Solve ln x + ln(x+1) = 7?
  • Thread starter Thread starter vt33
    Log
The discussion revolves around solving the equation ln x + ln(x+1) = 7, which involves natural logarithms and quadratic equations.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss transforming the logarithmic equation into a quadratic form, with some expressing confusion about the resulting equation and its factors. Questions arise regarding the correct interpretation of terms and the use of the quadratic formula.
Participants are actively engaging with the problem, exploring different methods for solving the quadratic equation derived from the logarithmic expression. Some guidance has been offered regarding the use of the quadratic formula and the evaluation of e^7.
There is a noted uncertainty about the transformation of the original equation and the implications of the term -e^7 in the quadratic form. Participants are also considering the limitations of factoring in this context.
vt33
Can anyone help me with this natural log?
ln x + ln(x+1) = 7
I've tried putting it in quadratic form but all I get is x^2 + x - 7=0
which doesn't seem to factor. What am I doing wrong?
ln x + ln(x+1) = 7
For one thing, your equation is wrong. It should be x^2 + x - e^7 = 0
Second, there are methods other than factoring for solving quadratic equations.
I've never seen this
well, thanks but, I've never actually seen this type of equation. What do I do with the -e^7, or what I mean is how do I factor that? Actually, should I just use the quadratic formula?
Your calculator should be able to give you a value for e^7. I am assuming that you know what e is. Then, using the quadratic formula should give you the correct answer.
thanks!
I see what you mean now, so I'll go crunch the numbers! Thanks a lot :)
  • · Replies 54 ·
  • · Replies 19 ·
  • · Replies 116 ·
