Unraveling the Mystery of Dark Matter and Its Relationship with Black Holes
  • Context: Graduate
  • Thread starter Thread starter stunner5000pt
    Black holes Holes
The discussion revolves around the relationship between dark matter and black holes, particularly focusing on why black holes do not continuously consume dark matter despite their strong gravitational pull. Participants explore concepts related to gravitational interaction, the distribution of dark matter in galaxies, and the implications for black holes at galactic centers.
  • Some participants propose that dark matter is affected by gravity, which is why it influences the rotational curves of galaxies.
  • Others argue that black holes do not behave like vacuum cleaners and that their gravitational influence at a distance is similar to that of other massive objects, such as stars.
  • A participant mentions that the relationship between supermassive black holes and dark matter is not as direct as previously assumed, suggesting that dark matter is not concentrated at the center of galaxies.
  • There is a discussion about the observed rotational velocities of galaxies, indicating that dark matter forms a diffuse halo rather than being concentrated towards the center.
  • Some participants note that the size and event horizon of black holes determine their interaction with matter, and that Hawking radiation is negligible for astronomical black holes.
Participants express differing views on the nature of dark matter's interaction with black holes and its distribution in galaxies. There is no consensus on the implications of these interactions or the relationship between dark matter and black holes.
Limitations in understanding arise from assumptions about the distribution of dark matter and the effects of black holes on surrounding matter. The discussion highlights the complexity of the gravitational interactions involved.
stunner5000pt
Hello everyone
if black holes have a gravitational pull so strong that nothing can escape, then why is it that they do not continuously consume dark matter? Yes i know its called dark matter because it doesn't not interact with other matter but it does have an effect on the rotational curves of galaxies for example. In this case the dark matter is contained within the galaxy rather than some kind of an ether theory. Would that not imply that dark matter is affected by gravity? Wouldnt that also imply that dark matter would feed a blakc hole located at the center of a galaxy, for example?
Astronomy news on Phys.org
The whole point of dark matter is that it DOES interact gravitationally with all other matter. This is the reason why it affects the rotation curves of galaxies. It simply does not interact electromagnetically (i.e. with light), hence, why we call it dark.
stunner5000pt said:
Hello everyone
if black holes have a gravitational pull so strong that nothing can escape...
Also, you may misunderstand what black holes do. They do not suck matter in like a giant vacuum cleaner. A black hole of mass X has no greater effect on matter at a distance than a star of mass X. i.e. if the sun were magically replaced by a black hole of the same mass, we would not notice here on Earth.
stunner5000pt said:
Hello everyone
Just to add what the gentlemen before me mentioned,it's not like a black hole keeps on taking in matter,we all know that it depends on their size(the event horizon being the boundary).Some stay for quite a long period others evaporate very quickly. About a month ago I read an article in which the conclusion they had come up with was that there is no direct correlation between the center of galaxies(Supermassive black holes) and dark matter which was initially assumed to be.
I believe you have misunderstood the whole rotational velocities of the galaxies against the center phenomenon.One of the ways in which we assume hypothetically the presence of DM is by studying the observed and our expected values of the rotational velocities of the galaxy cluster (elliptical ones I assume).What we notice is that at close to the center of the galaxy there isn't much deviation between our observed and expected values but as we go further from the center we surprisingly note that the observed curve has a fairly constant velocity (implying dark matter).We would expect the velocity to decrease by r^-1/2.
So you see dark matter isn't concentrated at the center.Someone correct me if I am mistaken.
Regards,
ibysaiyan
Hawking radiation isn't really an issue on astronomical scales, since temperature and power of emission scale with inverse mass and mass squared, respectively. Even light astronomical black holes already exist in the range of solar masses, so the radiation is almost nonexistant (which makes it hard to detect).
That's right. We find that rather than being distributed strongly towards the center like luminous matter is, the dark matter forms a fairly diffuse halo around (and in) the galaxy, which can often be quite a bit larger than the visual extent of the galaxy.
  • · Replies 17 ·
  • · Replies 73 ·
9K
