Electronics properties of C60 molecule
The discussion focuses on the electronic properties and geometric calculations related to the C60 molecule, specifically its surface area, volume, and the number of π electrons. The C60 molecule, modeled as a truncated icosahedron with 32 faces, 90 edges, and 60 vertices, has a mean diameter of 0.68 nm and a Van der Waals diameter of approximately 1 nm. Basic trigonometry and grade school math are sufficient to solve these problems, indicating that the calculations are straightforward for those familiar with the geometry of the molecule.
  • Understanding of geometric shapes, specifically truncated icosahedrons
  • Basic trigonometry for calculating surface area and volume
  • Knowledge of molecular structure and π electrons in organic chemistry
  • Familiarity with the properties of C60 fullerene
  • Research the geometric properties of truncated icosahedrons
  • Learn how to calculate surface area and volume of polyhedra
  • Study the electronic structure of fullerenes, focusing on π electron count
  • Explore the applications of C60 in nanotechnology and materials science
Chemists, materials scientists, and students studying molecular geometry and electronic properties of fullerenes will benefit from this discussion.
daffoddill
i need help to find :
1) a surface area and volume of a c60 molecule. Assume the structure is a truncated icosahedron (Faces=32, Edges=90 and Vertices=60). The mean c60 diameter is 0.68nm but Van der Waals diameter is closer to 1nm.
2) electronic properties of c60 molecule, like how many π electrons does a c60 molecule possess?
Thanks
Considering that these problems can be solved with basic trigonometry (1st) and grade school math (2nd) I really wonder where exactly you need help.
I do believe, however, that it is not a homework question. First, because you wouldn't be posting it here (it's clearly stated that this board is not for that) and second, because unless you actually are in grade school, a question like "count the number of electrons in a C60 molecule" is unlikely to be assigned as homework.
  • · Replies 19 ·
19K
9K
