Color physics and color perception
The discussion revolves around the perception of color and the physics of light mixing, particularly the differences between additive color mixing (light) and subtractive color mixing (paints). Participants explore the inconsistencies in how colors are perceived based on their light frequencies and the biological mechanisms behind color vision.
  • One participant notes an "inconsistency" in how mixing different light frequencies results in perceived colors, questioning the biological basis for this phenomenon.
  • Another participant challenges the idea of "mixing" light, emphasizing that mixing light does not yield new colors in the same way as mixing paints does.
  • A different viewpoint suggests that closely spaced dots of color can create the perception of a single color, akin to chemical mixing, and mentions the phenomenon of seeing complementary colors after staring at a color.
  • One participant highlights the incomplete understanding of color vision, particularly regarding the perception of certain colors like violet and brown, suggesting a need for further exploration of perceptual processes.
  • Another participant proposes two hypotheses regarding paint mixing: one about the reflection of light from individual specks of paint and another about the absorption of light frequencies leading to a new color perception.
Participants express differing views on the nature of color mixing and perception, with no consensus reached on the mechanisms behind these phenomena.
Participants acknowledge the complexity of color vision and the role of biological processes, but specific assumptions and definitions regarding color mixing and perception remain unresolved.
danihel
hi
i've been intrigued by certain "inconsistency" between light frequencies and the way we see them for some time by now.
if you mix red and yellow you get orange, if you mix red and green you get yellow, blue and yellow makes green, blue and green makes cyan. Now in all of these cases by mixing two colors corresponding to two different light frequencies you got pretty much a color corresponding to the light frequency somewhere in the middle.
But if you mix blue and red you'll get violet which is of higher frequency then blue, red being the bottom of visible spectrum. Is there some kind of biological reason why does the visible spectrum create a color wheel in our brain?
I'm not physicist and i don't understand the math of composing waves, could it be that our brain interprets different light frequency compositions as the same one color?
Biology news on Phys.org
What do you mean "mix" them?
As I understand it, you can't 'mix' light to gain a new colour. That only works with paints (or any colouring medium).
If you only have blue light and you send it through a red filter, it cancels out virtually all of the light (on an overhead projector you get a black patch where they cover each other).
well i don't know but i think if you put dots of those colors close enough together your eye will perceive them as one color as if you mixed them chemically also when you look too long at one color then close your eyes you see the opposite color on the "color wheel" which also points to the way we see as if the colors were enclosed in some kind of loop
danihel said:
hi
Color vision is not entirely understood. Certainly, we know about the different cones and the wavelengths they respond to. But I'm not sure we understand the (perceptual) origin of violet, brown, or pastel hues: those appear to require 'post-processing', as it were.
If I had to guess, I'd say that either:
A. The individual specks of paint reflect different light. When mixed, the spacing between these are so close that when your eye receives light from the paint, it is a mix of red and blue and happens to look purple. Don't know why.
B. The paint mixes and the new materiel doesn't reflect red and blue anymore, but actually reflects purple light.
The key here is that paint ABSORBS certain frequencies of light. When you mix all the paints together, there isn't any reflected, resulting in a Black color.
On the opposite, white light is a combination of all colors.
  • · Replies 207 ·
16K
  • · Replies 40 ·
  • · Replies 21 ·
