Is the Square Root of 0 Undefined?
The discussion centers around the question of whether the square root of 0 is undefined, exploring both real and complex number perspectives. Participants examine the implications of limits, algebraic definitions, and continuity in different contexts.
  • Some participants argue that the square root of 0 is defined algebraically as 0, since it is a solution to the equation x² = 0.
  • Others suggest that the limit of the square root function as x approaches 0 does not exist in the real numbers, but exists in the complex plane, where the function is continuous at 0.
  • A participant notes that the question can be interpreted differently depending on whether one considers limits or algebraic definitions.
  • Some participants express confusion over the implications of continuity and limits, particularly in relation to the definitions of functions and their domains.
  • There is a discussion about the behavior of complex functions and how they differ from real functions, particularly regarding limits from multiple directions.
  • One participant raises a point about a specific function that is defined everywhere but is discontinuous, highlighting the complexity of defining limits and continuity.
Participants do not reach a consensus, as multiple competing views remain regarding the definition of the square root of 0 and the role of limits in this context.
Limitations include the dependence on definitions of continuity and the domain of functions, as well as the unresolved nature of how limits behave in real versus complex contexts.
Alkatran
Is the square root of 0 undefined?
I was recently told that the square root of 0 is undefined because the limit of a square root didn't exist at 0. The reason is that from the negative direction you have i and from the positive direction you don't.
At first, i agreed with this. It made enough sense.
Then, about 5 seconds after i was out of the room, I pictured it on a complex graph (you know, y-axis = imaginary, x-axis = real) and noticed that the two points were getting closer together.
You could in fact say that .5i is closer to .5 than 1i is to 1. So, the limit does converge to 0 + 0i.
..right?
Mathematics news on Phys.org
This is all a red herring. Square roots are defined algebraically, not by limits. 0 is a solution to x^2 = 0, so 0 is a square root of 0.
[itex]\lim_{x \rightarrow 0} \sqrt{x}[/itex] does, in fact, not exist, but that's because [itex]\sqrt{x}[/itex] is undefined for x < 0. However, when you instead consider a complex square root function, the limit does exist and [itex]\sqrt{x}[/itex] is continuous at 0.
So it's right and wrong depending on wether or not you consider the complex plane... the fact that "i" was used to disprove it makes it... true? :rolleyes:
But I get it. Next time I'll just say it isn't defined and put a litte (in real number) next to it.
This is interesting. Does anyone else with ideas on the square root of 0?
Chalk one down to not reading "limit of" in the question. :blushing: But it's good to know the question can go either way.
No it isn't (interesting, I mean), or am I being dense?
sqrt is continuous as a function from R+ (the non-negative reals) to R, and from C to C, and even from R to C (all in the usual {metric} topology).
Since a "function" without a domain (and codomain) is not actually a function the question is easily answered.
matt grime said:
No it isnt, or am I being dense?
Can you explain that a bit more, please?
http://www.vbforums.com/attachment.php?s=&postid=1821439 : 3d graph with z axis as imaginary image, y as real image, and x as domain, the blue line is on z, and the red on y, they intersect, right?
I'll apologize for the ... roughness... of the graph. It's not an exact one, made with paint.
The square root of zero is zero.
I said to Mathematica to find the zeroes of [tex]\sqrt{x}[/tex] in the (-1,1) interval and the result was not exactly zero:
[tex]x \rightarrow -4.97297 \times 10^{-15} + 4.2265 \times 10^{-16} i[/tex]
:smile: Whats this?
Just to clarify, the question said "LIMIT OF" in it. So the question is: is the limit of the square root of x as x approaches 0 defined?
It isn't in the real numbers, but it is in the complex? Are (1,0) and (0,1) closer to each other than (2,0) and (0,2)?
Yes it's defined, and yes it's zero.
It isn't a function from R to R, so if we're even going to talk about having square roots of negative numbers, then we must mean from R to C, where it is obviously continuous at 0 since for any sequence of real numbers tending to zero, the square root tends to zero (in the metric and any other reasonable topology).
If you only want real output then the input can only be positive, and thus one cannot speak of taking a limit with a sequence of negatives.
Here is an interesting one though: consider the square root of e^{i\theta} as theta increases from 0 to 2pi. As you go round you find the square root of 1 from below is -1... how do we get round that?
That's right, the graph should have 2 red and 2 blue lines. They still all intersect at 0, though.
I suppose limits don't really tell us anyhting about whether or not a function is defined at a point for example the function f(x) = 1 if x is irrational, f(x) = 0 if x is rational is defined for all x in R yet it is discontinous about every point! Yet the limit of f(x)= x/x exists for x = 0, but the function is not defined at x = 0 (and hence there is a removable discontinuity at zero).
The interesting thing about limits in the complex numbers is that whilst in the real numbers for a limit to exist we say that the limit must be the same from both sides, in the complex numbers for a limit to exist it must be the same from all directions (and there are an infinite amount of directions!).
Whilst we're omn the subject, if we're taking the limit of a function whose domain closed subset of the reals (such as the non-negative numbers), do we still require that for the limit to exist at a point that both the left and right-sided limit exists?
Only if sequences of numbers approaching from the left and right are all members of the domain.
Some phenomena:
the function from R to R that is 1 for non-negative x, and zero otherwise is continuous when considered as a function with domain restricted to the no-negatives. (compare and contrast to the idea of a subspace topology), it is after all then just the function f(x)=1 for all x in the domain, which had better be continuous.
also note that something like f:Q \to Q, f(x)=1/(x^2-2), is continuous.
though surely it is better, if possible, to think of continuity in terms of inverse images of open sets.
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 33 ·
