Final Speeds After 2-Dimensional Collision
The discussion revolves around a two-dimensional collision problem involving two pucks with given masses and initial velocities. The pucks collide at an angle, and the goal is to determine their final speeds after the collision.
  • Participants discuss setting up the conservation of linear momentum equation and emphasize the need to treat velocities as vectors. They explore the direction components of the resultant velocities and question the formulation of these vectors.
The discussion is active, with participants collaboratively working on establishing the direction vectors for the velocities and reformulating the momentum equation. There is agreement on the need to find the magnitudes of the velocities, but no consensus on the final approach has been reached yet.
Participants are navigating the complexities of vector components and the implications of the collision angles. The problem setup includes specific angles and masses, but further details on the final speeds are not provided.
skonstanty
Puck A has a mass of 0.025 kg and is moving along the x-axis with a velocity of +5.5 m/s. It makes a collision with Puck B, which has a mass of 0.050 kg and is initially at rest. The collision is not head-on. After the collision, the two pucks fly apart with the angles: Puck A 65 degrees north of east and Puck B at 37 degrees south of east.
Find the final speed of a) Puck A and b) Puck B.
Please help!
Set up the equation of conservation of linear momentum; we'll take it from there..
m1vf1+m2vf2=m1v01+m2v02
That's true enough, as long as you remember that the velocities are, in general vectors (Right?).
Now, we have been given the DIRECTIONS of the resultant velocities; so what we need to determine in our problem, is the MAGNITUDES (speeds) of these velocities.
Do you agree that this is what you have to find out?
yes I agree
Okay:
Can you set up the DIRECTION vectors of your two resultant velocities, in terms of their east/north COMPONENTS?
sin65 and cos 37?
That's not vectors is it?
I'll take the first one for you:
Let [tex]\vec{i}[/tex] be the unit vector eastwards along the positive x-axis.
The unit vector northwards is therefore along the positive y-axis, that is [tex]\vec{j}[/tex]
The directionvector always have unit length, and we know that the first one is 65 degrees north of east.
Hence, we have the first direction vector:
[tex]\vec{d}_{1}=\cos(65)\vec{i}+\sin(65)\vec{j}[/tex]
can you set up the other direction vector?
Just to move this thread onwards, do you understand why the second direction vector is:
[tex]\vec{d}_{2}=\cos(37)\vec{i}-\sin(37)\vec{j}[/tex]
Secondly, now that you have the direction vectors, reformulate the conservation lof linear momentum by including these!
  • · Replies 35 ·
