Why is Grounding Essential in Car Electrical Systems?
The discussion centers on the necessity of grounding in car electrical systems, exploring the reasons for connecting various components to a common ground rather than using separate return wires. It touches on practical engineering considerations and the implications for circuit design.
  • Some participants propose that grounding serves as a common connection point for the electrical system, simplifying circuit design.
  • Others argue that using a single ground is not merely for convenience but is rooted in practical engineering and cost reduction.
  • There is a question about why a return wire is not connected directly to the battery, with some suggesting that a single ground is necessary for effective circuit completion.
  • One participant mentions that separate return wires may be used when low electrical noise is critical, although this is deemed irrelevant for certain components like lights and A/C fans.
Participants express varying views on the necessity and implications of grounding in car electrical systems. While some agree on the practicality of a common ground, others question the rationale behind it, indicating that the discussion remains unresolved.
Participants highlight the potential for exceptions in grounding practices, particularly in larger systems like the power grid, where a single ground may not be feasible. The discussion also hints at unresolved considerations regarding electrical noise and component insulation.
Individuals interested in automotive engineering, electrical engineering, and circuit design may find this discussion relevant.
Drakkith
Mentor
Why is everything in the electrical system in a car connected to ground, along with the battery? Is it just a convenient way to complete the circuit for everything without using many more wires?
That's what ground is, ground is the place you connect everything to. Most electrical systems have a ground that everything connects too.
There are some exceptions, and those occur when having a single common ground is infeasible, (for example, the power grid can't make a ground that spans the nation).
Why isn't the return connected straight back to the battery through wires instead of everything being grounded to chassis? Is there some reason everything needs to be connected to a single ground? The circuit simply needs to be completed for current to flow, so I don't see why everything is connected to ground other than for convenience.
Why would you want to use twice as many wires as you need to, and also go to the trouble of insulating every electrical component from the metal frame that it is attached to?
It isn't so much about "convenience" as "practical engineering" and "cost reduction".
The only time you would want to use a separate return wire is when a low electrical noise level is important, but that is irrelevant for things like lights, A/C fans, etc.
Ah ok, I see now. Thanks both of you!
13K
12K
  • · Replies 19 ·
