Audio Circuit Troubleshooting: Why Am I Getting No Sound From My Guitar Amp?
The discussion focuses on troubleshooting a guitar-related audio circuit that is producing no sound when connected to a guitar amplifier. The circuit includes a distortion block, a phaser, and an audio distribution amplifier, all utilizing operational amplifiers (op-amps). The user experiences faint, distorted sound before powering on the circuit, but silence follows activation. The consensus is that a mechanical wiring fault, such as a loose connection or short, is likely the cause, and a systematic approach to testing each stage of the circuit is recommended.
  • Understanding of audio circuit design, specifically using op-amps.
  • Familiarity with guitar amplification systems.
  • Basic knowledge of signal flow in audio electronics.
  • Experience with troubleshooting electronic circuits.
  • Inspect and test all mechanical connections in the audio circuit for faults.
  • Learn how to use an oscilloscope to visualize signal flow through the circuit stages.
  • Research techniques for diagnosing issues in multi-stage audio circuits.
  • Study the operation and troubleshooting of distortion blocks and phasers in audio processing.
Musicians, audio engineers, and hobbyists involved in building or troubleshooting guitar amplifiers and effects circuits.
chaoseverlasting
I've designed and constructed a guitar related audio circuit and I'm having a weird problem. When I tested the circuit at a friend's place yesterday we didnt have an amplifier with us so we used the inputs on his dvd to amplify the signal and listened to it on the TV's speakers.
Today I tried using the circuit with my guitar amp and I'm getting no sound what so ever. The weird part is that before I switch the supply on, I can faintly hear the input signal although it is very distorted. The moment I switch the supply on, I get nothing. Total silence.
I've got to submit this project soon and I'm at my wits' end. Any help would be appreciated.
The project consists of a distortion block, a phaser and an audio distribution amp all implemented using op amps with an adder at the end of it.
Most likely you have a mechanical wiring fault that came loose or shorted in transit.
Your gadget consists of several stages. Since you built it you can open it up.
If you inject your guitar (other other test) signal into each stage in turn and work back from the output amp unti you find the stage where the signal disappears.
go well
  • · Replies 20 ·
13K
