Express g(x) as g(x) = -2x2+ 0x + 1
  • Thread starter Thread starter Phoresis
The discussion revolves around finding the zeros of the functions F(x) = 2x² + 3x - 2 and G(x) = 1 - 2x². Participants are exploring how to apply the quadratic formula to G(x) and clarifying the structure of the function.
  • Participants discuss setting G(x) to zero to find its roots and question the interpretation of G(x) having "only two elements." There is also a mention of expressing G(x) in a standard quadratic form.
Some participants have provided guidance on finding the zeros of G(x) and clarified the use of the quadratic formula. Multiple interpretations of the function and its roots are being explored, with no explicit consensus reached.
There is a mention of a potential typo in the quadratic formula and confusion regarding the representation of roots, particularly the inclusion of both positive and negative values. The nature of G(x) as a parabola is also noted, indicating it may have two roots.
Phoresis
Ok i have the following question:
Given the functions:
F(x) = 2x^2 + 3x - 2
G(x) = 1 - 2x^2
Find:
a) the zeros of f(x), g(x)
Now I've used the following formula
Code:
[U]-b ±√b²-4ac²[/U]
        2a
and worked out the zeros of f(x) fine, but I'm confused as to how to accomplish the same for g(x) when g(x) only has 2 elements. Any help?
dont u just set g(x) = 0? if so you get [tex]x = \frac{\sqrt{2}}{2}[/tex]
G(x) = 1 - 2x^2
Find:
Code:
[U]-b ±√b²-4ac²[/U]
        2a
Why do think g has "only two elements"?
I hope I remember this correctly, but I believe you can express g(x) as
g(x) = -2x2+ 0x + 1
also, the c should not be squared in your quadratic formula.
yup thanks that was a typo
for g(x) :
x= +/- root2/2
You don't need the quadratic formula for g(x)
If you want to find the zeros:
g(x)=1 - 2x2
0=1 - 2x2
2x2=1
x2=1/2
Then, like faraz said [tex]x = \frac{\sqrt{2}}{2}[/tex]
but also
[tex]x = -\frac{\sqrt{2}}{2}[/tex]
oh i see. ok. thanks for your help guys. much appreciated.
how do you plot [tex]x = \frac{\sqrt{2}}{2}[/tex] on a graph though?
Why would you want to?
I guess if you really wanted to plot it an a x-y coordinate plane it would just be a vertical line at [tex]x = \frac{\sqrt{2}}{2}[/tex]
you don't need the negative in front of the fraction, because the result of the radical is automatically assumed to be plus and minus.
[tex]\sqrt{2} = \pm1.414...[/tex]
I believe the square root function (being a function and all) only outputs the positive root.
the function we are originally dealing with is not the square root function, it's g(x)=1 - 2x^2. Therefore, you have to include both + and - values of g(0). If you plot the graph, it is a parabola, so will have one, two, or no roots. In this case, it has two, one positive and one negative. Hence the +- of your square root.
