Shear Stress & Hole Compression
This discussion focuses on calculating shear stress on a pin and the resulting hole compression due to force load. Key failure modes identified include bearing stress, tensile failure, and pin push block out, with specific formulas provided for each: Bearing stress = pin diameter X plate thickness, Tensile failure = 2 X A1 X plate thickness, and Pin push block out = 2 X d X plate thickness. The overall approach emphasizes checking all failure mode stresses using the formula Stress = Force / Area.
  • Understanding of shear stress mechanics
  • Familiarity with failure mode analysis
  • Knowledge of basic material properties
  • Ability to perform stress calculations
  • Research the principles of shear stress in mechanical engineering
  • Learn about failure mode analysis in structural components
  • Study the effects of bearing stress on pin connections
  • Explore advanced calculations for tensile failure in materials
Mechanical engineers, structural analysts, and students studying material strength and failure modes in engineering applications.
PaulTO
Dear forum,
I need some guidence on how to solve shear stress on a pin and the hole compression due to force load on the pin. I haven't provided number as I can work those out later, but simply I am asking for a step by step!
[PLAIN]http://img835.imageshack.us/img835/8623/problemsb.jpg
You should consider 3 modes of failure:
1) Bearing stress = pin diameter X plate thickness
2) Tensile failure = 2 X A1 X plate thickness
3) Pin push block out = 2 X d X plate thickness, where d = distance from hole edge to part edge.
I hope I have understood your sketch. Basically, you want to check all failure mode stress = Force / Area.
  • · Replies 21 ·
