Calculate the torque about the elbow
  • Context: Undergrad
  • Thread starter Thread starter dg_5021
    Torque
The discussion focuses on calculating the torque about the elbow when performing the "curing weights" exercise with a 40-pound weight at a 55-degree angle. The torque formula used is torque = F * s * sin(θ), where F is the force and θ is the angle. The force was calculated as 177993 N, but the length of the arm (s) was not provided, leading to the conclusion that s must be treated as a variable for the torque calculation. Participants emphasized the need to estimate the length of the forearm to complete the calculation.
  • Understanding of torque and its formula: torque = F * s * sin(θ)
  • Basic knowledge of force conversion from pounds to Newtons
  • Familiarity with trigonometric functions, specifically sine
  • Concept of estimating physical dimensions, such as arm length
  • Research how to estimate the length of a human forearm for torque calculations
  • Learn about the implications of torque in biomechanics and sports science
  • Explore advanced torque calculations involving multiple forces and angles
  • Study the effects of different weights and angles on torque in physical exercises
Athletes, fitness trainers, biomechanics researchers, and anyone interested in understanding the physics of exercise and torque calculations.
dg_5021
Athletes sometimes do an exercise called "curing weights." This exercise consists of holding the arm from the shoulder to the elbow steady and snug against the body while pulling a weight to the chest. Calculate the torque about the elbow caused by a 40 pound weight that makes an angle of 55 degrees with respect to the body.
i know the formula is torque= F s sin()
I found the force by coverting pound 40pounds/2.2046kg= 18.144kg x 1000g= 18144 g x 9.81m/s =177993force
torque= F s sin(55)= (18144g)(9.81 m/s2) (s) sin(55)=
but what is s they don't give me the s. do i have to use other formula? am confused? please help
I suppose you need to estimate the length of an ordinary arm and calculate the torque accordingly.
Seems to me, if they don't give you a length of the forearm, then you have solved it completely with s left as a variable. Although, I would probably express the force as 178 KN, but that's just me.
10K
  • · Replies 23 ·
