Impact between human heel and orthotic wedge
The discussion revolves around the mechanics of impact between a human heel and an orthotic wedge, focusing on the forces at play during this interaction. Participants explore the modeling of the wedge as a spring system and the implications for reaction forces and center of pressure during loading conditions.
  • A podiatrist proposes modeling the orthotic wedge as a series of springs, suggesting that the wedge's deformation characteristics could influence reaction forces at the foot-wedge interface.
  • Some participants discuss the center of pressure, with one asserting it will not be located at the thick end of the wedge but rather within a specific range along the wedge.
  • A question is raised about the relationship between the wedge's angulation, the Young's moduli of the wedge and foot, and the resultant force distribution at the interface.
  • A participant challenges a friend's model, suggesting that the rate of change of velocity across the wedge would not be uniform, implying differing reaction forces across the interface.
  • Another participant clarifies that the coordinate system can be defined in various ways and supports the initial modeling approach while rejecting the friend's suggestion as incorrect.
Participants express differing views on the center of pressure location and the validity of various modeling approaches. There is no consensus on the accuracy of the friend's model or the implications of wedge angulation on force distribution.
Limitations include assumptions about the wedge's material properties and the simplifications made in modeling the foot's impact. The discussion also highlights the dependence on the definitions of coordinate systems and the conditions under which the models are applied.
Simon Spooner
Please be gentle, I'm not a physicist, I'm a podiatrist trying to find the answer to a problem that has been confusing me! I hope you can help.
In podiatry we often use foot orthoses in an attempt to alter the magnitude, location and timing of reaction forces at the foot's interface. A simple 2D cross-section model of the heel section of an orthotic could be a wedge of homogenous material. If we assumed that under loading conditions the wedge of material functions in a linear fashion in accordance with Hookes Law, then effectively we could model the wedge as a number of springs increasing in resting length from the thin end of the wedge to the thick end. As the resting length of each of these "spring" columns of material increases so the spring constant (K) should decrease.
If the heel of the foot is modeled as an homogenous mass and impacts vertically downward onto the wedge then the foot should come into contact with the highest side of the wedge first. Assuming that the foot does not rotate but continues to load onto the wedge until static equilibrium is achieved, there should be a longer period of compression between the foot and the wedge at this point of initial contact than lower areas of the wedge-foot interface, which came into contact later as the foot and wedge deformed under loading. Yet, there should also be greater vertical linear displacement per unit load at the thick end of the wedge than at the thin end- right?
So, while the thick end of the wedge may have deformed more than the thin end by the time static equilibrium exists (velocity = zero) between the foot and the wedge, but the thin end of the wedge will push back with a higher reaction force per unit deformation. So would the centre of pressure always be under the point of initial contact at the time of static equilibrium between the foot and the wedge?
I hope that makes sense. My maths isn't so hot, so explanations without too much algebra would be really helpful. Many thanks for any help you can provide.
Simon Spooner: No, if the x-axis is horizontal, and the wedge thick end is located at x = 0 mm, and if the end of the contact area is at x = xn, then the centre of pressure would be located at somewhere within the range 0.30*xn ≤ x < 0.50*xn. I.e., the centre of pressure will not be located at x = 0 mm.
Thank you. How did you define those numbers?
I'm not sure the x-axis is horizontal since it is the reaction forces at the foot-wedge interface which we are really interested in. Is there are relationship between the angulation of the wedge and the Young's moduli of the wedge and foot and the resultant force distribution at the interface?
A friend tried to help me with this and he modeled the situation with angular displacement and suggested that in this situation the rate of change of velocity across the wedge would be the same at any point, therefore the reaction forces would be the same across the entire wedge-foot interface. Is this accurate?
Once again, thanks for your help.
Simon Spooner: It doesn't matter if the x-axis is horizontal or vertical. You can define the coordinate system either way. Therefore, in post 2, I defined the x-axis as horizontal, and the y-axis as vertical.
Post 1 defines the foot (heel) as having no rotation, which is realistic. I would currently recommend the method of post 1. The method suggested by your friend in post 3 currently sounds incorrect. In the method of post 1, the foot will simply translate downward until it reaches equilibrium.
13K
  • · Replies 0 ·
