Investigating Infinite Summation: Calculating Sn 0-10
The discussion centers on calculating the sum Sn of an infinite sequence defined by t0 = 1 and tn = (x ln(a))^n/n!. Participants clarify that the sequence does not exhibit arithmetic or geometric properties due to the differing ratios and differences between terms. The main task is to compute the sum of the first n terms for n values ranging from 0 to 10. The conversation also highlights the importance of notation clarity, particularly avoiding the use of "x" for both variables and multiplication.
  • Understanding of infinite sequences and series
  • Familiarity with factorial notation and its application
  • Basic knowledge of logarithmic functions, specifically natural logarithms
  • Experience with mathematical notation and clarity in communication
  • Learn how to compute sums of infinite series using convergence tests
  • Explore the properties of factorial functions in series
  • Study the application of logarithmic identities in sequences
  • Investigate the differences between arithmetic and geometric sequences
Mathematicians, calculus students, and anyone interested in the analysis of infinite sequences and series calculations.
Peter G.
I am investigating the sum of infinite sequences.
such that: t0 = 1 and tn = (x ln (a))n/n!
They tell me to first consider the following sequences of terms:
1, (ln 2)/1, (ln 2)2/2x1, (ln 2)3/3x2x1
They then ask me to calculate the sum Sn of the first n terms of the sequence for when 0 is bigger or equal to 0 and smaller or equal to 10.
I couldn't however, find any relationship between the terms that indicates whether the sequence is arithmetic or geometric.
So are they asking me to simply grab the calculator, calculate the values and write them down?
Thanks,
Peter G.
Please, please, please don't us "x" both as a variable and as a multiplication symbol!
I think you mean 1, (ln 2)/1, (ln 2)2/(2)(1)m, ln(2)3/3(2)(1), etc.
"0 is bigger or equal to 0" surely that's not what you meant!
There is a reason for that! The quotient ((ln 2)/1)/1= ln(2) while ((ln(2))2/2)/(ln(2)/1)= ln(2)/2. Since those are not equal, this is NOT a geometric sequence. The difference ln(2)/1- 1 is not equal to ((ln(2))2/6)/((ln(2))/1) so this is NOT a an arithmetic sequence.
Yes, although I have still not figured out what you really meant by "calculate the sum Sn of the first n terms of the sequence for when 0 is bigger or equal to 0 and smaller or equal to 10". Is it possible that you are to calculate this for n between 0 and 10?
Thanks,
Peter G.
I am very sorry. Reading over what I wrote is actually quite embarrassing. I actually moved this post to the Calculus region because I saw a post with the exact same problem as mine there.
I made some progress with the people in that section, but, in case I have future doubts and you want to contribute, you can find the topic at:
https://www.physicsforums.com/showthread.php?p=3276495&posted=1#post3276495
Sorry once again,
Peter G.
  • · Replies 25 ·
