| New Reply |
Adding two velocities |
Share Thread | Thread Tools |
| Apr30-11, 12:23 PM | #1 |
I saw on this forum a formula by Einstein in his special relativity theory something like
Velocity sum = (velocity one plus velocity two)/ (1+velocity1*velocity2/the speed of light squared) With small velocities, they simply seem to add together, but at higher velocities, they add less and less together. So, does this imply that high velocities warp space? I guess that is what it says, hmmm? But how? Does increased velocity expand space? I put the formula into an excel spreadsheet and played a bit and I also notice that if velocities can exceed the speed of light, if you add them, they get slower, at least up until they are each 1 quintillion meters per second, in which case they equal to zero, and no matter how much larger the velocity from there, they still add to zero. What does this imply? |
| Apr30-11, 06:57 PM | #2 |
v1 and v2 both have to be less than c.
| Apr30-11, 10:05 PM | #3 |
| Apr30-11, 10:11 PM | #4 |
| Apr30-11, 10:37 PM | #5 |
Seeing as to get to a velocity near c in the first place, you will have to start with some lower velocity (which will be less than c), then when you add another velocity to it (which will also necessarily be lower than c) using the formula, you will never be able to reach a number that's higher than c.
So: no slower than light v can ever reach or exceed c. HOWEVER... ![]() You have a point that it doesn't really forbid higher than c numbers, but they must start > c - and using the velocity formula you should see that they will never go below c. You have stumbled upon the case for the hypothetical particles known as tachyons. |
| May1-11, 06:16 AM | #6 |
It is still anti-intuitive to me that two light beams approaching each other are not adding speeds. If you drive down the road one way and I approach from the other way and we are each going 60MPH, we approach each other at 120 MPH. In the special relativity velocity formula, if we changed the speed limit to 60 MPH, we would be approaching each other at 60 rather than 120 MPH. Safer, yes. Realistic, no. |
| May1-11, 06:26 AM | #7 |
getting up to speed. You turn a light on or you broadcast an RF wave and it instantly is at top speed. This is likely why Einstein used it as a constant. In that regard, I can see why he did so. WOW, isn't that interesting? In a sense light is binary - either on or off. I am glad I found this forum. You guys really get me think ing.
| May1-11, 06:27 AM | #8 |
As an exercise, write down the Lorentz transformation that corresponds to a velocity v in the x direction, and apply it to the description of a particle moving at velocity w in the same direction. Find the relationship between the resulting x' and t' coordinates. What do you get?
| May1-11, 06:47 AM | #9 |
| May1-11, 09:30 AM | #10 |
Mentor
| May1-11, 10:14 AM | #11 |
| May1-11, 12:16 PM | #12 |
What is the experimental basis of Special Relativity? |
| May1-11, 12:53 PM | #13 |
| May1-11, 02:01 PM | #14 |
Just so I'm on the right track, the problem you're outlining is that the equations don't work with imaginary (impossible) speeds?
| May1-11, 02:44 PM | #15 |
I know of another example in Newtonian Physics where the same kind of misunderstanding can take place. (I was a victim of that misunderstanding.) P.S. Most of the big guns on this forum appear to be taking a break. They deserve it. |
| May1-11, 04:05 PM | #16 |
Its good to have some intuition, but don't let it keep you from getting to know nature better, nature has spoken. |
| May1-11, 05:27 PM | #17 |
Intuition falls apart as you approach light speed. Your idea that velocities add in the newtonian sense is accurate to within the precision that you can typically measure it. If you actually went out and drove two cars at each other at 60 MPH, you'd see them close at something like 120.0000000001mph due to the relativistic effects. Now, can you detect something that is ~0.0000000001% of a difference between Newtonian and relativistic velocity additions? No. Now when you start colliding particles at large fractions of the speed of light, the differences become extremely obvious. |
| New Reply |
| Thread Tools | |
Similar Threads for: Adding two velocities
| Adding Vector Velocities | Introductory Physics Homework | 2 | ||
| Eulerian velocities to Lagrangian velocities | Calculus & Beyond Homework | 3 | ||
| Adding Relative Velocities | Special & General Relativity | 3 | ||
| When adding up velocities, is it possible to produce 1+1=1? | Special & General Relativity | 3 | ||
| Adding Velocities with Special Relativity | Introductory Physics Homework | 5 | ||
