What's the Difference Between dy/dx and d/dx in Calculus?
  • Context: Undergrad
  • Thread starter Thread starter guss
    Derivative
The discussion revolves around the differences between various notations for derivatives in calculus, specifically focusing on dy/dx, d/dx, and f'(x). Participants explore the implications of these notations in the context of explicit and implicit differentiation, as well as their interpretations when differentiating functions with respect to different variables.
  • Some participants express confusion about the distinction between taking a derivative and specifying the variable with respect to which the derivative is taken, such as in dy/dx versus d/dx.
  • It is noted that dy/dx indicates the derivative of y with respect to x, while d/dx applies to whatever function follows it.
  • One participant argues that viewing d as an infinitesimal can lead to misunderstandings, suggesting it should be treated purely as notation.
  • Another participant explains that in implicit differentiation, dy/dx is used because y is considered a function of x, whereas in explicit differentiation, the function's dependence on x is clear.
  • There is a discussion about the notation's usefulness in functions where variables may not be immediately clear, such as f(a) versus f(x).
  • Some participants express frustration with the notational conventions and their implications for understanding derivatives.
  • Clarifications are made regarding the meaning of "with respect to" in the context of differentiation.
Participants generally agree on the basic definitions of the notations but express differing opinions on their clarity and usefulness. Some participants remain confused about the implications of these notations, indicating that the discussion is not fully resolved.
There are limitations in the discussion regarding the assumptions about the functions being differentiated and the clarity of the notation used. Some participants mention specific cases that may not apply universally, leading to potential misunderstandings.
This discussion may be useful for students new to calculus, educators looking for insights into common student misconceptions, and anyone interested in the nuances of mathematical notation in differentiation.
guss
I do not understand the difference between taking the derivative, and taking the derivative with respect to x, or taking the derivative with respect to y (or any other variable).
If I take the derivative of y = x^2, I get y' = 2x. What if I use the dy/dx or just the d/dx notation?
so
dy/dx y = dy/dx x^2
vs
d/dx y = d/dx x^2
another example I don't understand would be
dy/dx = 2x
vs
d/dx = 2x
vs
f'(x) = 2x
I know that the d refers to an infinitesimally small number, but I just don't understand the difference between the stuff I mentioned before.
Someone enlighten me?
if you differentiate y(x^2 ) with respect to x, you get 2xy. if you differentiate y(x^2) with respect to y, you get x^2. What is going on is that one is seen as a function of x and the other is seen as a function of y. That is, when y(x^2) is a function of y, after fixing some x, x^2 is just a constant, so that differentiating y(x^2) is like differentiating cx with respect to x, resulting in c.
Sorry, I still don't understand.
Ok, so let's assume you have a function y = f(x). There's a lot of overlap in notation, as you'll see:
f'(x) means to take the derivative of y with respect to x. (same with y')
d/dx means to take the derivative of whatever's after it with respect to x. For example:
d/dx (y), would mean to take the derivative of y with respect to x.
dy/dx means to take the derivative of y with respect to x. The "numerator" indicates what function you're taking the derivative of. The "denominator" indicates what you're differentiating with respect to.
I actually hate the d/dx notations and similar...
The point is that y is actually a function, so it would be better to write y(x)=x^2. Then dy/dx just means the derivative of y with respect to x. So
[tex]\frac{dy}{dx}=y'[/tex]
If you want to evaluate this in the point 2, then you write
[tex]\frac{dy}{dx}(2)[/tex].
Sometimes, if y=x^2, for example, people will write
[tex]\frac{dx^2}{dx}[/tex] instead of [tex]\frac{dy}{dx}[/tex]
But I consider that to be very bad notation...
so
dy/dx y = dy/dx x^2
vs
d/dx y = d/dx x^2
The first notation doesn't really makes sense to me. The second would be
[tex]\frac{d}{dx}y:=\frac{dy}{dx}=y'[/tex]
dy/dx = 2x
vs
d/dx = 2x
vs
f'(x) = 2x
The second notation doesn't make sense to me. The first does, but I think it's bad notation and I would never use it...
Not everybody will agree with me, but don't think of d as infinitesimal number. Just think of d as a notation. Thinking of d as a number causes you to make mistakes, and in (standard) real numbers, there are no such things as infinitesimals...
Thanks guys, I think I'm starting to understand it.
I still don't understand what this means, though. What does "with respect to" really mean?
It's nothing spectacular, "with respect to" simply indicates the variable.
For example, if f(x)=2x, then f'(x)=2, and the notation would be df/dx
But we can also write f(z)=2z (this is the same function), then we would write df/dz.
This notation is useful for functions like f(x)=2a+x, where a is just a number. If we do not know what our variable is (x in this case), then we could both have df/dx or df/da. The dx in the bottom just serves as a reminder to what the variable of f is called...
Ahh, I understand now. Thanks!
But, last question. In explicit differentiation, d/dx is usually used to represent the change of the function with respect to x. However, in implicit differentiation, why is dy/dx used to represent the change of a function with respect to x?
When you do implicit differentiation, y is a function of x so when you take the derivative of y with respect to x you write it as a derivative of the function.
When you differentiate an explicit function of x you know how the function is dependent on x so you can explicitly take the derivative. You don't know how y depends on x, so you must leave it as dy/dx.
I'm not really following, sorry. I think we have a misunderstanding in your second paragraph. I am just referring to an equation like y = 5x^2 or f(x) = 5x^2. Not a multivariable expression.
Ah, I thought you meant implicitly differentiating a function like xy^2 = 2x/y or similar.
I'm not quite sure what you mean then by explicit and implicit differentiation.
As far as the notation does, d/dx is just a differential operator, meaning take the derivative w.r.t. x, where as dy/dx applies the operator to some function y.
That is what I mean.
It seems to me that you are talking about something like f(x) = x^2 + 6y.
Could you rephrase what you said before? Sorry for being unclear I am very new to this stuff haha.
Yay, I finally understand. I was just overthinking it.
It's funny how the solution to something so simple can seem so amazing after finally understanding it.
