New Reply
3-phase Delta Induction machine problem for Electric Machines and Power Electronics
Share Thread Thread Tools
May1-11, 05:15 AM   #1
A [tex]\Delta[/tex] connected induction machine is to start from a source of 480V, 60 Hz.
The motor ratings are :
4 poles, [tex]\Delta[/tex] connected, 480V, 60 Hz, [tex]X_{ls}\,=\,X_{lr}\,=\,4\,\Omega[/tex], [tex]X_m\,=\,50\,\Omega[/tex], [tex]R_s\,=\,0.25\,\Omega[/tex], [tex]R_r\,=\,0.4\,\Omega[/tex].
Find the current in the windings and the torque of the motor and the current at the line side.
2. Relevant equations
[tex]I_S\,=\,\frac{V_{l-l}}{\left(R_s\,+\,j\,X_{ls}\right)\,+\,\left(j\,X_m\,||\,R_r\,+\,j\,X_{ lr}\right)}[/tex]
[tex]I_R\,=\,I_S\,\frac{j\,X_m}{R_r\,+j\,X_{lr}\,+\,j\,X_m}[/tex]
[tex]P_{gap}\,=\,n_{ph}\,|I_R|^2\,\left(\frac{R_r}{s}\right)[/tex]
Where [tex]n_{ph}[/tex] is number of stator phases.
[tex]T\,=\,3\,\frac{P_{gap}}{\omega_s}\,\frac{p}{2}[/tex]
Where p is number of poles.
The above equations are not given explicitly anywhere, but an example uses them so I think they are right.
3. The attempt at a solution
At starting, s = 1.
[tex]I_S\,=\,\frac{480}{\left(0.25\,+\,j\,4\right)\,+\,\left(j\,50\,||\,0.4\ ,+\,j\,4\right)}\,=\,62.1^{\angle\,-85.6^{\circ}}[/tex]
[tex]I_R\,=\,\left(62.1^{\angle\,-85.6^{\circ}}\right)\,\frac{j\,50}{0.4\,+j\,4\,+\,j\,50}\,=\,57.5^{\ang le\,-85.2^{\circ}}[/tex]
[tex]P_{gap}\,=\,(3)\,(57.5)^2\,(0.4)\,=\,3967.5[/tex]
[tex]T\,=\,3\,\left(\frac{3967.5}{377}\right)\,\left(\frac{0.4}{1}\right)\,= \,63.14\,Nm[/tex]
Does that look right? How do I get the current at the line side?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
May1-11, 04:42 PM   #2
I found an equation that will possibly give line side current...
[tex]I_{line}\,=\,\sqrt{3}\,I_{ph}[/tex]
But what is [tex]I_{ph}[/tex]? Is it [tex]I_S[/tex] or [tex]I_R[/tex]?
New Reply
Tags
3 phase, electric machines, induction machine, power electronics, power engineering
Thread Tools
Similar Threads for: 3-phase Delta Induction machine problem for Electric Machines and Power Electronics
Thread Forum Replies
3 Phase Induction Machines Electrical Engineering 15
Electric machines & power electronics - PMAC machine connected in Y, 4 poles... Engineering, Comp Sci, & Technology Homework 2
Electrical Machines and Power Electronics - 3 phase, 6 pole induction motor Engineering, Comp Sci, & Technology Homework 1
3 Phase Machine Line Current problem Engineering, Comp Sci, & Technology Homework 2
Electric Power & Machines BSc .. Possible Nuclear Engineering MSc ? Academic Guidance 5
