Can Spanning Sets Help Me Understand Vector Spaces Better?
The discussion revolves around the concept of spanning sets within vector spaces, specifically focusing on polynomial spaces and spaces of continuous functions. The original poster presents a problem involving a set of polynomials and questions whether it spans a given vector space. A related inquiry involves determining the linear dependence or independence of a set of sine functions.
  • Participants explore the implications of linear dependence and the conditions required for a set to span a vector space. They discuss the relationship between the number of vectors and the dimension of the space. Questions arise about the linear independence of sine functions and the methods to test it, including substituting values and differentiating equations.
The discussion has progressed with participants providing insights into the implications of linear dependence and exploring methods for testing linear independence. Some participants have offered guidance on substituting values and differentiating equations to simplify the analysis. The conversation reflects a collaborative effort to clarify concepts and approaches without reaching a definitive conclusion.
Participants are working within the constraints of homework guidelines, which may limit the extent of direct solutions provided. There is an ongoing examination of assumptions related to the definitions of spanning sets and linear independence.
Spectre5
I don't totally understand spanning sets...
Can anyone explain this problem to me:
let V = set of all polynomials with degree of 2 or less (a vector space_
let S = {t + 1, t^2 + 1, t^2 - t}
Does S span V?
I know that (t^2 + 1) - (t + 1) = t^2 - t
But I just don't see what that tells me...
This tells you that your vectors are linearly dependent. Do you see why?
V has dimension 3. You have 3 vectors. If they spanned V, then they would be linearly dependent as well (it's crucial here that you have 3 vectors and dimV=3, you probably have a theorem to this effect). You've shown they aren't linearly dependent, so can they span?
Thanks for the response...so basically since I reduced the system to 2 equations, it cannot span since it needs 3 equation (vectors) to span it?
Another related question...
let V = vector space of all continuous functions on the interval of the real numbers
let S = {sin(t), sin(2t), sin(3t)}
is S of V linearly dependent or lineraly independent?
Thanks any help
Ok, I get the first question now...since they are linearly dependent, they cannot span a 3d vector space...that makes sense now. I still need some help on that second question though please.
nvm, you got it.
Thanks any help
Have you tried the usual test for linear independence? Do you know what it is?
well, I do know what it is...but this is all I get when using it:
(c1)sin(t) + (c2)sin(2t) + (c3)sin(3t) = 0
I don't know where to go from there
A set is linearly independent if no vector in the set can be written as a linear combination of of the other vectors
Good. That has to be true for all values of t, so try substituting some in and see what you can say about the coefficients.
Ideally you want to put in a value of t that will make 2 of the terms vanish so you can elimante one coefficient.
E.g. to shaow t and cos(t) are independent, look at
(c1)t+(c2)cos(t)=0 (*)
Put in t=0 and get:
(c1)0+(c2)1=0
so c2=0 and equation (*) becomes
(c1)t=0
Put in t=1, and we see c1=0, therefore t and cos(t) are independent.
well, I cannot think of any values that would cancel out just two of the constants...which leads me to believe it is linearly independent...but how do I know that there are no values...how do I know I am not missing some value?? Is there a better way of doing it?
It's not necessary to have 2 of them cancel, that would make life easier, but it's not necessary and not always possible.
Putting in any value of t (where they don't all vanish), will allow you to simplify your equation by getting a relation among c1, c2, and c3. Can you find any values of t to make one of them vanish and not the other 2?
how about pi/2
then we have (c1) - (c3) = 0
so (c1) = (c3)
Good. You've simplified down to 2 variables now. Try substituting in some more values of t to see what you can get.
Another thing you can do is differentiate your equation. You'll get a linear combination of cos's. Try putting in convenient values for t and see what you can say about c1 and c2. You could differentiate this again if need be.
differentiate the equation, and you get all of it in terms of cos...then plug in pi/2 again and only the c2 term is left.
so (c2)*2*cost(2(pi/2)) = 0
So (c2) = 0
And then back to the original eq..
(c1)[sin(t) + sint(3t)] = 0
WE can ignore the (c2) term since it is always 0, but now if t = pi/2, then the equation is true for any value of (c1) and thus any value of (c3)
Ok, c2=0 like you showed, that's good, and you had c1=c3 from earlier post, so you're down to (c1)[sin(t) + sint(3t)] = 0, which must be true for all t.
What value of c1 makes (c1)[sin(t) + sint(3t)] = 0 for all values of t? What if t=pi/6, what can you say about c1?
then c1 is 0 and c3 must also be 0...ok
It doesn't matter that c1 could be anything when t is pi/2 because the equation must hold for all values of t, and that is only possible when c1 is zero.
Therefore, the set is linearly independent.
Thanks for all your help!
