Is DDR2 Compatible with RDRAM? Help Me Upgrade My System!
  • Thread starter Thread starter Argentum Vulpes
The discussion revolves around the compatibility of DDR2 memory with RDRAM, particularly in the context of upgrading an older computer system. Participants explore the specifications and performance characteristics of RDRAM and DDR2, as well as the requirements for motherboards that support these memory types.
  • One participant outlines their planned system upgrade, emphasizing the need for a motherboard that supports RDRAM at 800MHz, expressing concerns about DDR2 boards only operating at 400MHz.
  • Another participant discusses the high latency of RDRAM compared to DDR SDRAM, suggesting that DDR SDRAM is generally faster and more efficient.
  • A different participant notes that newer DDR2 motherboards can exceed 400MHz and mentions the necessity of using an LGA775 processor with these boards, highlighting the need for a compatible power supply.
  • One participant reiterates the performance differences between RDRAM and DDR SDRAM, providing benchmark data to support their claims about speed and efficiency.
  • Another participant argues that while RDRAM may be slightly faster in certain scenarios, the cost-effectiveness of DDR SDRAM makes it a more viable option for upgrades.
  • One participant concludes that RDRAM is slower in practical tests, suggesting that this should inform the decision-making process for upgrades.
Participants express differing views on the performance and efficiency of RDRAM versus DDR SDRAM, with some asserting that DDR SDRAM is superior, while others argue for the potential advantages of RDRAM in specific contexts. There is no consensus on the best memory type for the upgrade.
Participants reference various technical specifications and performance metrics, but there are unresolved assumptions regarding the practical implications of these differences in real-world applications. Additionally, the discussion does not clarify the specific compatibility of DDR2 with RDRAM.
Argentum Vulpes
I'm in the process of updating my four year old system. This will include a new Motherboard, CPU, Memory, Video, and HD (if I need to a new power supply). Here is a list of what I'm planning on running
CPU:
P4, 3.0Ghz, 800Mhz FSB, 1MB L2 cache, HT tec.
Memory:
184 pin, 512k, Non-ECC, RDRAM PC-800
Video:
nVIDIA GeForce 6600/300MHz, 128MB, PCI-Express x16
HD:
80GB, IDE ULTRA ATA133
The problem I run into is trying to find a motherborad that will run this all. I can find plenty of DDR2 boards, however they have the problem of only running the memory at 400Mhz clock speed. This is unacceptable for me as I want to get the entire system to run at the best clock speed, and I see this as 800Mhz with RDRAM. As a side note overclocking is not an option for me because I don't have enough time or motivation to learn it and do it right. So if anyone can point me in the direction of the motherboard I need or clear up any misconceptions I have about DDR2 please help me.
Computer science news on Phys.org
There are several issues with RDRAM:
-High latency: ~30ns vs ~5ns for DDR SDRAM.
-16 or 32 bit vs 32 or 64 bit for DDR SDRAM (double the memory bandwidth).
-DDR2, IIRC transfers data 4x per clock tick just like RDRAM
-That 800mhz is actually 200mhz quad-pumped (ddr 400 is 200x2).
Add all that together, and DDR SDRAM is faster, which is why RDRAM is pretty much dead. According to my Sisoft Sandra benchmark software, PC800 in dual channel will give you about 1400MB/s while PC3200 DDR Sdram (not ddr2) will give you 1700.
The newer DDR2 motherboards have speeds now greater than 400mhz, so the numbers are getting better. RDRAM was prohibitively expensive, and also the fact that you had to run them in pairs was bad.
If you want to run DDR2, you'll need the new motherboards based off the 915 or 925 chipsets. Intel makes a good board, and so does Asus. Note two things - one, for these boards, you need the new LGA775 processor, not the S478 ones. (So you'd be looking for the Intel 530 or so processor.) Two, if you get a motherboard with the 925 chipset, then you need a 24-pin power supply, which is not the normal kind. They aren't much more expensive, but different.
although you are correct with your above conversion remember DDR ram is actually less efficient in the utilization of its bandwidth only able to utilize about 65% of its bandwidth to where Rambus is able to utilize about 85% of bandwidth so the performance is actually about the same of the 2 in real life situations the rambus actually is slightly faster then the ddr keep in mind that rambus is also offered at a higher clock speed with the 1066 rambus but the slight performance margin is way less then the margin of cost so take that into consideration when upgrading
RDRAM is slower in real life tests so that should about sum it up for you :P
