Solving for the New Speed of a Brick on a Waxed Plank
  • Thread starter Thread starter meh6287
    Speed
The discussion focuses on calculating the new speed of a brick sliding down a waxed plank with reduced friction. Initially, the brick's speed at the bottom of a 2.0m plank inclined at 30 degrees is 2.5 m/s. The coefficient of friction is halved after waxing, necessitating a reevaluation of the forces acting on the brick. The correct approach involves analyzing the forces, including gravitational and frictional components, to derive the new acceleration and subsequently the new speed.
  • Understanding of Newton's laws of motion
  • Knowledge of gravitational force and its components
  • Familiarity with the concept of friction and its coefficients
  • Basic algebra for solving equations
  • Calculate the new acceleration of the brick using the modified friction coefficient
  • Determine the new speed of the brick at the bottom of the plank
  • Explore the relationship between potential energy and kinetic energy in inclined planes
  • Investigate the effects of varying coefficients of friction on motion dynamics
Physics students, educators, and anyone interested in understanding dynamics and motion on inclined planes, particularly in the context of frictional forces.
meh6287
A brick slides down a wooden plank 2.0m long tilted so that one end is at a height of 1.0 m. The brick's speed at the bottom is 2.5 m/s. The plank is then sanded smooth and waxed so that the coefficient of friction is half what it was before and the brick is slid down again. What is the new speed of the brick at the bottom?
so far all i could come up with is that theta=30degrees
then i did f x m x g x cos30) x d = .5 x m x v^2 for the first block
and then w=(.5f x m x g cos30) x d = .5 x m x v^2 for the second block
then i canceled the m's, and i pluggedin v for the first equation and solved for f, and then i tried to put that f value in and come up with an answer for v but that answer is wrong because it comes out to less than 2.5 which doesn't make sense.
Thank you for the help in advanced.
But you haven't taken into account the change in potential energy here!
Here's how I would do this, NOT using energy.
The force normal to the plank is -mg cos(30) and the force in the direction of the plank is -mg sin(30). The friction force along the plank is fmg cos(30) (f is the coefficient of friction) so the total force on the brick along the plank is
f mg cos(30)- mg sin(30)= -mg(sin(30)- fcos(30)) and of course, the acceleration is
a= -g(sin(30)- fcos(30)). After a time T, the velocity of the brick will will be aT and the distance traveled is (a/2)T2.
Let T be the time required for the brick to reach the end of the plank. Then we are told that aT= 2.5 and (a/2)T2= 2. Since T= 2.5/a, the second equation is
(a/2)(2.52/a2)= 2 so 4a= 2.52 or a= 2.52/4.
You can now solve for f. Once you know that, halve it to find the new friction coefficient, find the total force along the plank just as before and the acceleration from that.
