[Please delete old thread] Kid going down slide
The discussion revolves around calculating the minimum distance between a parent and a child sliding down a parabolic water slide. The parent is positioned at coordinates (1,2) while the edge of the pool, serving as the vertex of the parabola, is at (3,1). The equations of the parabola are provided in both vertex form, f(x) = 2(x-3)^2 + 1, and standard form, f(x) = 2x^2 - 12x + 19. The participant seeks to determine the minimum distance using calculus, specifically by computing the distance from the normal line to the point (1,2).
  • Understanding of parabolic equations and their properties
  • Knowledge of calculus, specifically derivatives and normals
  • Familiarity with distance formulas in coordinate geometry
  • Basic skills in algebra for manipulating equations
  • Study the concept of normals to curves in calculus
  • Learn how to derive and apply the distance formula in coordinate geometry
  • Explore optimization techniques using derivatives
  • Review the properties of parabolas and their equations
This discussion is beneficial for students studying calculus, particularly those focusing on optimization problems involving geometric shapes, as well as educators looking for practical applications of parabolic equations in real-world scenarios.
aeromat
A parent takes their child to a water slide which is shaped similar to a portion of a parabola (see diagram). There is an elevator 3m from the edge of the pool. The elevator takes the rider to the top of the slide which is 19m above ground. The rider slides down and falls into pool from height of 1m. The parent (he is 2m tall) is standing 1m from the elevator and wishes to take a picture of the child when they are closest to the parent. What is the MIN. distance between parent and child?
Let the elevator be at (0,0)
So the parent is at (1,2)
The edge of the pool is (3,1)
So, the edge of the pool is the vertex; (3,1)
We know (0,19)
Equation(s):
f(x) = 2(x-3)^2 + 1 <-- vertex form
f(x) = 2x^2 - 12x + 19 <-- standard form
f'(x) = 4x - 12
Now I am 100% sure I got these equations correct. I am now stuck because I don't how to get that point (x,f(x)) that will give the minimum distance.
Would it work if I compute the distance from this line equation's normal to the point using the equation:
d = |Ax + By + C| / root[A^2 + B^2]
Subbing in for (x,y), the point (1,2)?
What do you mean by this? It looks like you mean the normal to the tangent on the parabola at the point (x,f(x)), and you would be able to solve it this way but it involves calculus.
  • · Replies 17 ·
