Communication Matrix Homework Problem #10: How to Indicate Arrows
The discussion focuses on Problem #10 of a communication matrix homework assignment, specifically how to indicate arrows of transmission based on the matrix values. The matrix consists of "0"s and "1"s, where a "1" in row x and column y indicates a transmission from node x to node y, necessitating the drawing of an arrow from x to y. The nodes involved are labeled A, B, and C, and the solution requires drawing two double-ended arrows based on the matrix's values.
  • Understanding of communication matrices
  • Basic knowledge of graph theory concepts, specifically nodes and edges
  • Familiarity with binary matrices and their interpretation
  • Ability to visualize and draw directed graphs
  • Research how to construct and interpret communication matrices in detail
  • Learn about directed graphs and their properties
  • Explore examples of transmission matrices in network theory
  • Study the implications of double-ended arrows in graph representation
Students studying communication theory, educators teaching graph theory concepts, and anyone interested in understanding the representation of data transmission in network models.
h1a8
Problem #10 here http://i54.tinypic.com/2mn2nwp.jpg
What is the idea behind a communication matrix and how to indicate the arrows of transmission?
I've been a math tutor/teaching for many years and have not come across this type of problem. I can't help several students with it simply because I don't know where to start. All I need is some basic idea of what is going on here and I should be fine.
The rows are labeled "from" and the columns are labeled "to". Also there are only "0"s and "1"s in the matrix. There is a transmission from "x" to "y" if and only if there is a "1" in "row x, column y" so you draw an arrow from "x" to "y" in that case.
Here, the "nodes" are A, B, and C so draw three points, labled "A", "B", and "C" and draw the arrows as I said above. For this particular problem you should have just two "doubleended" arrows.
Thanks! I got it.
  • · Replies 18 ·
