Reaction moment in cantilever beam
The discussion focuses on the reaction moment in cantilever beams, specifically how the wall exerts a reaction moment at the fixed end. It is established that the reaction is a result of the support arrangement, which may include a built-in or encastre condition that generates a moment through a couple formed by toe and heel forces. The reaction moment is not limited to the centroidal axis; other points along the beam can also experience moments depending on the load and support conditions. The interaction between the beam and wall involves horizontal forces that create a couple, contributing to the overall reaction moment.
  • Understanding of cantilever beam mechanics
  • Knowledge of support conditions (built-in, encastre)
  • Familiarity with moment and couple concepts in structural analysis
  • Basic principles of force equilibrium in beams
  • Study the principles of moment distribution in cantilever beams
  • Learn about the effects of different support conditions on beam behavior
  • Explore the calculation of reaction forces and moments in structural engineering
  • Investigate the role of shear and bending moments in beam analysis
Civil engineers, structural analysts, and students studying mechanics of materials will benefit from this discussion, particularly those focused on cantilever beam design and analysis.
gladius999
Hi guys,
I'm wondering how the wall of the cantilever beam (a beam fixed at one end at a wall) can exert a reaction moment? Is this done by the wall pushing back on the cantilever beam away from its centroidal axis?
Also is the reaction moment always applied to the centroidal axis of the cantilever beam? If i took a chop at the y plane at a point in the beam does only the centroidal axis contain a moment? Or do other points along the beam in the y-axis have a moment too?
At the plane of the intersection between the wall and the beam, do I always take moments around the centroidal axis when there is a load? i.e. always take that point as the pivot?
Thanks
Well firstly the word cantilever refers to projecting part that has no support at the free end.
The reactions are a property of the support arrangement, not the fact that there is a cantilever projection.
At the support there may be zero moment because the cantilevered or projecting section is 'balanced' by a projection in the other direction exerting equal but opposite moment.
The fixed end of the cantilever may be built in or encastre, in which case the moment is generated as a couple between toe and heel forces as the fixed end jams in its mounting.
You can regard this suport condition as a clamping action.
The fixed end may be bolted down either onto a horizontal support in which case the back end exerts an uplift force and the front or toe end a downward force. The reaction provide a couple.
These vertical couple providing forces are in addition to the vertcal support force reaction.
Finally the projection may be bolted to a vertical wall, in which case the moment is provided by horizontal forces forming a couple between the lower reaction resisting pressure on the wall and the upper reaction resisting pull out from the wall.
29K
24K
