| New Reply |
Radiation and human health |
Share Thread | Thread Tools |
| May3-11, 08:42 AM | #1 |
Just been revising radiation for an upcoming exam, and was wondering which form of radiation, [tex]\alpha[/tex], [tex]\beta[/tex] or [tex]\gamma[/tex] is the worst to be exposed to?
Ionising power decreases from alpha to gamma, but penetrating power increases from alpha to gamma. Which is more important when considering how much damage each form can do to human cells? |
| May3-11, 11:29 AM | #2 |
What is exactly being held constant here? Typically, for a given dose (energy deposited per unit mass) the gammas and electrons will have the approximately the same biological response, while the alpha will tend to be more damaging.
| May3-11, 06:02 PM | #3 |
Your question is too open. You need to have some specifics about how the doses were recieved. If you have alpha or beta radiation striking your skin, its pretty much harmless.
| May12-11, 05:18 AM | #4 |
| May12-11, 05:28 AM | #5 |
Hi there,
If you are standing next to a radioactive sources, the only real danger comes from the gamma radiation. The alpha and the beta are stopped pretty much by the first layers of skin. If you inhale or ingest some radioactive materials, then the alpha can start causing serious damage. Although, never neglecting the effects of beta and gamma, the alpha radiation will probably be the most harmful for the body. Cheers |
| May14-11, 04:04 PM | #6 |
The weighting factors for x-rays, gamma rays, electrons, positrons and muons is 1.
Neutrons range from 2 to 20 depending on their energy. Alpha particles are 20! Consequently, alpha radiation is far more dangerous to human health. X-rays, gamma rays and electrons generally form diffused ions when they strike human cells. Normal healthy cells are well equipped to easily repair such ions. Alpha radiation on the other hand is between 10 to 1000 times more concentrated and likely to cause chromosome damage; especially if injected or inhaled. Radon gas (alpha radiation) is the 2nd leading cause of lung cancer while electrons and x-rays can be used to cure a wide variety of cancers. |
| May14-11, 04:10 PM | #7 |
| May16-11, 02:36 AM | #8 |
Hi there,
Cheers |
| May16-11, 10:55 AM | #9 |
The difference is that, at higher energies, the alphas can penetrate much more deeply. For instance, a 1 GeV alpha has a CSDA (continuous slowing down approximation) range of approximately 38 cm. |
| May16-11, 05:49 PM | #10 |
Remember that the wieght factor of 20 is for damage to biological tissue. If it isn't in your body, then it doesn't even count as exposing yourself to it. |
| May17-11, 02:12 AM | #11 |
Hi there,
Why not talk about TeV or PeV as a matter of talking. Of course, if you are expose to radiation with this type of energy, it is hard to talk about radiation protection. Their penetrating power is so great that the only was to protect against, is to run a galaxy far, far away. Cheers |
| May17-11, 08:37 AM | #12 |
A 1 GeV photon still has a weighting factor of 1 compared to 20 for an alpha. So for a given dose, the alpha is much more damaging. You wanted to know why we would even consider an Alpha having a weighting factor of 20. It can penetrate at high energies. LBNL ran a radiotherapy beam of alphas for 30 years or so. They treated over 2000 patients here. Need weighting factors for radiotherapy. Radiotherapy uses typically uses higher energies than 5 MeV for protons and heavier ions. In addition, there is a high energy background of heavy ions permeating the solar system called galactic cosmic rays (energies from MeV to TeV are typically considered). This radiation environment interacts with the space station and the shuttles. It contributes to the total dose received by astronauts. |
| New Reply |
| Tags |
| cell, dangerous, health, radiation |
| Thread Tools | |
Similar Threads for: Radiation and human health
| Radiation Health Benefits | General Discussion | 8 | ||
| What produces human radiation? | Biology | 1 | ||
| WiFi radiation? Is it dangerous for health? | Computing & Technology | 12 | ||
| Electromagnetic Radiation and Health | General Physics | 4 | ||
| Radiation Health Effects URLS | General Physics | 98 | ||
