How can I draw angles using just a ruler and compass?
  • Thread starter Thread starter Dooga Blackrazor
    Angles Drawing
The discussion revolves around the methods for drawing angles using only a ruler and a compass, focusing on specific angles such as 60 degrees, 35 degrees, and 45 degrees.
  • Participants explore various methods for constructing angles, including the use of trigonometric functions to determine distances on a coordinate plane and the concept of angle bisecting. Some participants question the clarity of the methods and seek further explanation.
The discussion includes multiple interpretations of how to approach the problem, with some participants offering suggestions and methods while others express a need for clearer guidance. There is no explicit consensus on a single method, but various ideas are being explored.
The original poster mentions the need to show curves to signify compass use and references a point of intersection as part of the drawing process. There may be constraints related to homework requirements that influence the discussion.
Dooga Blackrazor
Does anyone know a site that shows how to draw angles using only a ruler and a compass?
60 degree, 35 degree, 45 degree angels ect.
Any explanation on how to do this would be great. I have to show curves to signify that I used the compass and I believe the method involves a point of intersection.
Thanks,
Imagine a x/y coordinate plane with a line segment going out [tex]\theta[/tex] counterclockwise from the positive x-axis. You can use the fact that the tangent of that angle will give you the slope of that line to figure out the x and y distance you have to go to make that angle.
If that's not clear, just draw a triangle and label your theta. Using trig functions you can find the possibilities for the sides.
Drawing a 45 degree angle is easy if you know how to bisect an angle (you use two coordinate axes).
Define A value for one of your sides use trig to find the value for the other two sides given an angle.
From this set your compas to your first desired length draw a circle
then set the compas to the second length pick a point along the first circle draw your next circle
I finished my bonus sheet, I appreciate everyone's help.
