What gives atoms the properties of a chemichal?
  • Thread starter Thread starter silenzer
    Atoms Properties
The properties of atoms are determined primarily by the arrangement of electrons, which is influenced by the charge of the nucleus. Atoms are classified by element, with each element exhibiting unique properties due to its specific electron configuration. For example, water is a molecular compound formed from hydrogen and oxygen atoms, while air is a mixture of gases, predominantly nitrogen and oxygen. When air is compressed to the density of water, it retains different properties due to its distinct atomic composition.
  • Understanding of atomic structure and electron configuration
  • Basic knowledge of molecular compounds and mixtures
  • Familiarity with covalent bonds and their role in chemical properties
  • Concept of atomic classification by elements
  • Research atomic structure and electron arrangement in detail
  • Study the properties of molecular compounds versus mixtures
  • Explore the concept of covalent bonding and its implications in chemistry
  • Investigate the periodic table and how atomic charge affects element properties
High school students, chemistry enthusiasts, and anyone interested in understanding the fundamental properties of atoms and their implications in chemical behavior.
silenzer
Firstly be easy on me, I'm 17 and still in high school and English is not my first language so go easy on the heavy vocabulary.
I was wondering the other day, what is it that gives atoms its properties? If air would be densed to as thick as water, would it have the same properties? I don't think so, but why not?
Chemistry news on Phys.org
First a little terminology:
Atoms are classified by element. The organization of electrons in the atoms gives each element its properties.
Water is a molecular compound .. it is made up of hydrogen atoms and oxygen atoms bound together by covalent bonds.
Air is a mixture of gases .. it is mostly molecular nitrogen (two nitrogen atoms bound together) and molecular oxygen (two oxygen atoms bound together), with some other minor components.
So, you are correct that air compressed to the same density as water will have different properties that liquid water. The reason for this is because the different substances are composed of different combinations of atoms at the molecular level. I can't go much beyond this without getting significantly more technical.
As SpectraCat wrote, it is arrangement of electrons that defines properties. This arrangement is in turn function of the nucleus charge, that is different for each element (but identical for all atoms of the same element).
24K
  • · Replies 21 ·
